Go Back   Automotive Forums Car Chat > Racing > Formula-One
Old 03-23-2003, 12:35 PM
GTi-VR6_A3's Avatar
GTi-VR6_A3 GTi-VR6_A3 is offline
H4X0R T0 T3H M4X0R
Send a message via AIM to GTi-VR6_A3
Differenece between F1 and INDY
alright guys please dont flame me but what is the difference between these two cars. i dont get to watch f1 but i do sometimes watch indy. i know they arent the same types of cars so what is different?
-GTi-VR6_A3
-GTi-VR6_A3
Old 03-23-2003, 01:27 PM
NSX's Avatar
NSX NSX is offline
Send a message via ICQ to NSX Send a message via AIM to NSX Send a message via MSN to NSX Send a message via Yahoo to NSX
Re: Differenece between F1 and INDY
-GTi-VR6_A3
Indy is a 2.5L Turbocharged V8 Engine I think, and they use manual transmissions.
F1 is a 3.0L Naturally Aspirated Engine with semi-automatic shifters.
As well, F1 is much bigger in both North American & Worldwide than Indy, thus, the cars are much more advanced.
Old 03-23-2003, 01:35 PM
kaoru-tochiro's Avatar
kaoru-tochiro kaoru-tochiro is offline
Banned
Indy cars are also bigger and heavier.
Old 03-23-2003, 02:13 PM
GTi-VR6_A3's Avatar
H4X0R T0 T3H M4X0R
Re: Re: Differenece between F1 and INDY
i thought that engines varied form car to car
-GTi-VR6_A3
-GTi-VR6_A3
Old 03-24-2003, 05:44 AM
freakray freakray is offline
AF Modelrater
Re: Re: Re: Differenece between F1 and INDY
In which?
He explained the difference.....F1 doesn's use a turbo, it is a naturally aspirated V10.
The only variation from car to car in F1 is the engine supplier....
There is also a hige difference in the look of the cars, find some photos of IRL cars and compare them to photos of some of the current F1 cars and you will notice huge differences.....
AF User Guidelines
Old 03-24-2003, 01:24 PM
RallyRaider's Avatar
Zomby Woof
A few years back I'd have said the difference was that F1 was a series with an open set of regulations designed to promote the best of technical expertise and skill. While CART was a closely regulated, built to a cost championship, with pure entertainment as it's goal.
These days I'm not so sure...
Old 03-24-2003, 03:35 PM
dbartoschek's Avatar
dbartoschek dbartoschek is offline
Aren't F! cars basically fully automatic...only time the need to do anything is in the pitstops
Not mine, but a nice one! I have one though, 1994 Bonneville, new vehicle section doesn't let you list more then 1 car.
Old 03-24-2003, 04:02 PM
AF Modelrater
:hehehe: :hehehe: :hehehe:
Nope, they have to select the gears, it's not a case of park, D & R there is a full 6 gears to work up and down through.....
AF User Guidelines
Old 03-24-2003, 10:58 PM
Zomby Woof
At least some of the cars in F1 have seven forward gears plus reverse.
Don't know exactly what the rule is at the moment but I think that fully automatic gearboxes are legal, if they would be of benefit is another matter.
In the past the teams used manual upchanges but often had downchanges programmed in for each corner. It is the on the downchanges that it used to be possible to over-rev or "buzz" the engine. The result of which was a damaged engine.
Would be very surprised if some of the top teams didn't have the whole gearchange sequence mapped out for any given circuit so it could be programmed in for the perfect lap. That type of thing would work well in qualifying, especially given the new single lap format. In the race however there would be a lot of different variables going on that would make it more difficult to programme. The driver would have to have much more input.
You can bet that the lower budget teams would still do all the gearchanges with the paddles. In fact I recall the Forti team, which raced in the mid nineties, only had a CART or motorbike style sequencial gearbox - they couldn’t afford anything else. In fact that car used to bounce around on the track a lot like Indycars do. The better cars of the time like Williams and Benetton appeared to be much smoother, almost on rails in comparison.
Old 03-24-2003, 11:06 PM
GTi-VR6_A3's Avatar
H4X0R T0 T3H M4X0R
and now i know..............the REST of the story.
thanks for explaining it to me wihtout being asses. i knew about f1 having seq man gears but i didnt really know much about indy
-GTi-VR6_A3
-GTi-VR6_A3
Old 03-25-2003, 07:07 AM
crayzayjay's Avatar
crayzayjay crayzayjay is offline
CFA
Fully automatic gearboxes were around last year in F1, and I believe they still are now. I think they’re going to be banned, and rightly so. Even the low budget teams in F1 have automatic shifts.
As for the differences between the cars, the technical details are endless, but when it comes to how they drive, drivers who have raced in both CART and F1 say that F1 cars are more “delicate” to drive, requiring a lot more precision and therefore being more difficult to drive. Over a (non-oval) circuit, an F1 car is substantially quicker than a CART car, as was proved on the only track both series use, which is the Montreal GP (Circuit Gilles Villeneuve)
Old 03-25-2003, 12:17 PM
hakka's Avatar
hakka hakka is offline
Champ cars (Indy Cars) use one of two chassis (Reynard or Lola) with a Ford engine(I think that is all, but there may be more.) These engines make around 750hp@14,000rpm. The cars weigh around 1700lbs with a driver. They use steel brakes and a semi-automatic gearbox with six or seven speeds.
Formula 1 cars are manufactured by many different companies; every competing team must manufacture their own chassis. The constructors are Ferrari, McLaren, Williams, Renault, Jordan, Jaguar, Sauber, Toyota, BAR, and Minardi. Each manufacturer also has their own engine, though these can be purchased from someone else (i.e. Williams-BMW or McLaren-Mercedes). These engines make a variety of powers; the highest figure I've heard is 930hp@19,700rpm from McLaren. These cars weigh about 1300lbs. They use carbon brakes and fully automatic gearboxes (though they will be banned mid-season).
Basically, it can all be summed up from the lap times at the Circuit Gilles Villeneuve in Montreal:
CART Pole - C. DaMatta - 1:19.0
F1 Pole - J. P. Montoya - 1:12.8
Old 03-27-2003, 03:10 PM
Xerxes Xerxes is offline
hmm....the CART car used to have a 2.6L turbo engine, but now both cart and indy use 3.5L NA engines. just to clear that out. both use semi-automatic trannys. you can see the difference in the body works, and the advantages that the F1 cars have is their weight and their breaks:flash:
Old 03-27-2003, 03:29 PM
Veyron's Avatar
Veyron Veyron is offline
Smile
I just went to the CART site, they are currently running 2.65 turbocharged engines. IRL is running naturally asperated engines. CART is going to be burning petrol instead of alcohol in acouple years, they want to use something more in line with road cars.
Old 03-28-2003, 02:17 PM
my mistake.....I had thought they went to NA engines....they always talk about the torque, and the torque settings.....they prob. just went to a smaller turbo or something like that
