Old 03-23-2003, 12:01 PM
Smoakie976's Avatar
Smoakie976 Smoakie976 is offline
Question dohc valve cover
I bought what I thought was a b16a2, but I found out from comparing my valve cover to the one on my friends 2000 si that it is different.
The difference is that he has a honda symbol and I do not.....mine say honda motor company and dohc.... his says dohc and has a honda symbol.......although the engine block says that it is a b16a2.......can someone tell me what the hell is going on here!!!!!!!!
Old 03-23-2003, 12:59 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
B16A2
But the fact is.it is too easy to change them out if they get nasty so people do.Also with all the different ones out there it matters where it was made.
Old 03-23-2003, 03:34 PM
94civic's Avatar
94civic 94civic is offline
you probably have a jdm b16a valve cover or it could be a jdm b16a sir2 motor.
are the dohc letters bigger than the vtec? if so then you have a jdm valve cover.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 03-23-2003, 03:42 PM
JDM siRII's don't have B16A2,they just have B16A.There are USDM valve covers that have vtec>dohc,it doesn't matter you can't tell shit from a valve cover.
Old 03-23-2003, 03:57 PM
94civic's Avatar
b16a jdm valve cover:
http://store3.yimg.com/I/supercaraut...e_1701_4837723
b16a usdm valve cover
http://vcx.freeservers.com/Honda/civ..._front3_sm.JPG
see the difference.
i'm just telling him that he may have a jdm valve cover and that doesn't mean that i said that he had a b16a sir2. i just said that maybe he has one. listen to the keyword that i used "...it COULD be a jdm b16a sir2 motor."
too much to list
Old 03-23-2003, 04:02 PM
see the difference.
I don't need a visual thank you,I have seen them,I said that because he stated that he thinks he got a B16A2,not nescessarily in response to you.
Old 03-24-2003, 11:32 AM
Smoakie976's Avatar
the stamp on the engine says b16a2, but the valve cover differs from my friends b16a2 in his 2000 si. If I had a camera I would take a pic of it, but I don't!
1998 honda civic ex
b16a2
AEM intake
HKS HiPower Exhaust
Skunk2 front camber kit
2000 Si rear bumper
99 Si wheels
pioneer p9000 head unit
jl audio w6 12" sub
Rockford Fosgate 250x2 amp
976 Crew
Old 03-24-2003, 11:43 AM
If it has a B16A2 stamped on the block,than most likely it is a USDM 99-00 si or Canadian siR.It could possibily be a EDM 92-00 siR (II) motor,but I doubt it.Do you have it in your car yet?
Old 03-24-2003, 11:54 AM
Smoakie976's Avatar
I just looked at the valve cover and the DOHC is bigger than the vtec and then at the bottom it says honda motor co. if it was jdm wouldn't it be red though? Mine is black.
1998 honda civic ex
b16a2
AEM intake
HKS HiPower Exhaust
2000 Si rear bumper
99 Si wheels
jl audio w6 12" sub
976 Crew
Old 03-24-2003, 11:57 AM
Smoakie976's Avatar
Yes...it has been in my car for about 9 months now....but my vtec is currently not working as you know and I have not ran it at the track....it is also bone stock, but still a dohc vtec!
1998 honda civic ex
b16a2
AEM intake
HKS HiPower Exhaust
2000 Si rear bumper
99 Si wheels
jl audio w6 12" sub
976 Crew
Old 03-24-2003, 12:05 PM
Did you have to do any wiring to adapt the OBD IIb that the 99-00 si runs?Another thing it could be,is a 96-97 delsol,if it plugged straight in this would be a good possibility,since it is OBD II.And I believe the valve cover is DOHC vtec.
Old 03-24-2003, 12:23 PM
Smoakie976's Avatar
It did not plug straight in I had to get a 96+ gsr ecu so i got a 99 gsr ECU. So what do you think....that would be sick if it was a SiRII, but I totally doubt it too! Also isn't the delsol engine just a B16a?
1998 honda civic ex
b16a2
AEM intake
HKS HiPower Exhaust
2000 Si rear bumper
99 Si wheels
jl audio w6 12" sub
976 Crew
Old 03-24-2003, 12:30 PM
What did you have to do to get it to plug in?Why are you running a GSR ECU and what did you do about the ECU looking for the IAB sensor?Did you get it chipped?The US delsol from 94-95 was the B16A3 from 96-97 it was the B16A2.
Old 03-24-2003, 12:37 PM
Smoakie976's Avatar
sorry man I could not tell you what I did because I did not do it...i had a friend in San Diego do it for me....he told me what to get and I did it....he told me to get a Si shift linkage and shifter, OBD II GSR ECU, EX wiring harness, and Si axels, and then in like 5 hours I was running a swapped engine! Miracles can happen! I thought that I would never get rid of that 1.6 SOHC!
1998 honda civic ex
b16a2
AEM intake
HKS HiPower Exhaust
2000 Si rear bumper
99 Si wheels
jl audio w6 12" sub
976 Crew
Old 03-24-2003, 01:17 PM
Are you throwing CEL codes,besides your vtec?With that ECU you should be.
