Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-24-2009, 07:04 AM
jthomp23777 jthomp23777 is offline
Dash Lights
On 2001 Tahoe. The dash and radio lights sometimes are dim and other times they have completly quit working. Adjusted the dimmer knob next to the light switch and they will flicker and sometimes the lights will adjust fine. Notice that at times it gets hot around the housing that contains the light switch and dimmer knob. I realize that the light switch and dimmer are one complete unit. I was wondering if the resister is going bad in the dimmer knob.
Old 01-25-2009, 05:50 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Dash Lights
Could be bad or lose wire.
Pull it out where you can get to wiring and dash light feed and check it out.
Good luck
MT
Old 01-27-2009, 03:16 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Dash Lights
The dimmer contacts inside the switch may be oxidized. Don't know if you can open it to clean them with some fine sand paper, but that may help. Squirt some electrical contact grease on them afterwards to protect from oxidation & for lubrication.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
