Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-24-2009, 03:44 AM
SherA SherA is offline
Question '92 Regal Custom turn signals not working
All of the sudden, both my left and right turn signals don't work any more. The turn signal indicator lights on the dash don't come on, either, and it makes no clicking sound at all. However, the hazard lights still work.
I checked the fuse and it was good. I replaced the flasher unit under the dash near the steering column and still no joy. What else could it be?
Thanks in advance for any help
Old 01-26-2009, 03:44 AM
cstruc cstruc is offline
Re: '92 Regal Custom turn signals not working
Any bulbs burnt out? Otherwise it might be the actual turn signal switch behind the steering wheel, I think mine is starting to go because it only works when you have the signal lever in the exact right position. They run for about $100 on eBay.
Old 01-26-2009, 03:59 AM
I didn't check the bulbs because the hazard lights still work so I didn't think that could be the problem.
I'll check out the turn signal switch. Thanks for your help.
Old 01-26-2009, 02:53 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The turn signal switch in your car is a very common issue. The contacts get worn and cause the turn signals to stop working. There are 2 different ones depending on if your car has the accessory controls on the steering wheel. It will require you to remove the steering wheel to replace.
AC-Delco D6226a w/o steering wheel accy controls
AC-Delco D6214a with steering wheel accy controls
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-27-2009, 02:37 PM
Logitech Logitech is offline
I have a dead cruise control issue on my 2001 Buick Regal LS with 143,000 miles, regular 6 cylinder engine.
Blinkers seem to work fine. Wipers work fine. Just the cruise control died. Would replacing the turn switch on mine get me my cruise back? I don't really need it, but want it to work if I ever have to sell the car.
Old 02-06-2009, 04:17 AM
Hi, I just wanted to let you guys know that I got the turn signals working now.
As it turns out, I had replaced the hazard flasher unit instead of the turn signal flasher. Once I realized my mistake, I replaced the correct one and that was all it took to fix the problem. I'm really glad it wasn't the switch
Thanks again for all your help.
