Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-23-2009, 05:40 PM
k.taylor k.taylor is offline
my 1990 bonneville keeps idling and shuting off !!!NEED HELP!!!
my 1990 bonneville keeps idling and shuting off AND KEEPS DOING IT
i just replaced the distribution cap new spark plugs and wires and a new air filter i still the same thing keeps happen
please help this is my first car
Old 01-24-2009, 06:53 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: my 1990 bonneville keeps idling and shuting off !!!NEED HELP!!!
Did your mechanic charge you for this cap?
Your car does not have a distributor cap. It uses a magnetic trigger system, with no cap. Obviously, you should not have to pay for something that cannot be done.
I suspect it's a dirty or malfunctioning Idle Air Control (IAC) motor.
This device is on the intake manifold, beside the throttle blade. It allows a measured amount of air into the engine during idle. It's fairly common for it to get dirty and malfunction.
It can be removed and cleaned-out with some spray-can carb cleaner and a toothbrush.
Old 01-27-2009, 05:43 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
First, pull the codes. Thats always where you want to start with issues like this as guessing leads to spending money on un-needed parts.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 04-02-2009, 09:02 AM
charlie239 charlie239 is offline
where is the TDM in a 1995 pontiac boneville?
