Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 01-23-2009, 03:38 PM
ajprobashi ajprobashi is offline
Vibration with Check Engine, Trac Off
Ok, here is the problem. I have a 1999 ES300. Bought it used. Around 122k miles. Everything is fine except the check engine light and the traction light came on. On top of that the car staretd to vibrate a little bit when I started the engine once. I turned my car off and started it back up again and the vibration stopped. While the car was vibrating the check engine light was blinking and once the vibration was gone the check engine light stayed solid.
I went to autozone and got it checked, and it gave me a code regarding O2 sensors. Now I changed only one sensor however, I'm guessing the other 2 sensors needs to be replaced as well. Would a car vibrate if it had faulty O2 sensors?
Old 01-30-2009, 11:02 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Vibration with Check Engine, Trac Off
There are three O2 sensors: 2 located before the cat (one for each cylinder bank, placed in the exhaust downpipes) and one post-cat O2.
I presume the diagnostic code told you which sensor was at fault...it has that capability. Ideally all three should be changed, especially if you change brands, but technically they should all perform within OEM specs.
To answer your question, yes a faulty O2 can cause poor idling and poor fuel economy. They detect the amount of unburned hyrdocarbons (fuel) in the exhaust stream and use that to adjust the amount of fuel injected into the cylinders according to your driving state...economy, performance, etc. This is to maximaze fuel efficiency and minimize pollution. When one goes bad, particularly one of the pre-cat sensors, the ECM has to resort to a set of pre-determined fuel/air "maps" to compensate, resulting in engine inefficiencies. hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
