Old 01-23-2009, 02:37 PM
Bryan C. King's Avatar
Bryan C. King Bryan C. King is offline
Send a message via AIM to Bryan C. King
1983 Pickup, Shift Linkage (Bushing)
I have a 1983 Chevy (GMC) 3/4 Ton pickup. Column shifter is extremly loose and I determined that the bushing located at the piviot point on the frame rail is worn out. Does anyone know where I can get a replacement bushing, spring and or metal cup that mounts to the frame rail? Thanks in advance.
Old 01-23-2009, 06:15 PM
j cAT j cAT is offline
Re: 1983 Pickup, Shift Linkage (Bushing)
you can make a bushing to fit....use copper/brass pipe etc....
Old 01-26-2009, 06:52 PM
Thanks for your reply, I figured I could fab up something, just wondering if anyone offered the parts so I didn't have to go that route. The part that is really worn out the the metal bracket that mounts to the frame rail.
Old 01-27-2009, 05:52 PM
acewelderman's Avatar
acewelderman acewelderman is offline
Try LMC Truck
I have bought a lot of parts from them with good luck!
JUST WELD IT !!
Old 07-13-2013, 10:25 AM
victonate victonate is offline
Hi Bryan C. Did you ever fix your 95 Tahoe? I was reading the thread and there weren't anymore posts that told what the end result was. I have a 97 GMC Savana van that:
-Has no spark
-Fuel pump does not work unless you jump the relay
-No communication to computer with diagnostic tool
Your situation seemed similar. I hope you can help.
Thanks,
Dan
Old 07-13-2013, 07:27 PM
maxwedge maxwedge is offline
A990 racer
Sounds like a bad ign switch, not the key cyl, the ign switch itself.
Old 07-14-2013, 05:08 PM
But the engine turns over.
Old 07-14-2013, 06:49 PM
777stickman 777stickman is offline
Welcome to the forum. Just wondering why we're responding to a 4 1/2 year old post that has nothing to do with a tranny bushing issue .
With that said...........
These Ign switches have 5 contacts in them. One is dedicated to the crank circuit only. Another contact is dedicated to fuses powering the Ign, ECM, etc.
So, as Max said it could very well be the Ign switch!!
Good Luck
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 07-15-2013, 05:45 AM
thanks for the info 777. I will check into the ignition switch.
