Go Back   Automotive Forums Car Chat > Ford > Contour
Old 01-23-2009, 08:55 AM
Joat_65 Joat_65 is offline
ABS Sensor cable location
Does anyone know were the multi-plug connection is for the front ABS wheel sensors? I found the rear multi-plug connectors under the rear seat as described in Haynes service book but there is no location reference to the fronts.
Old 01-23-2009, 02:10 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: ABS Sensor cable location
My service manual says:
Front:
Removal:
1. Raise vehicle on hoist.
2. Remove front brake anti-lock sensor retaining bolt and front brake anti-lock sensor from front wheel knuckle.
3. Disconnect front brake anti-lock sensor wiring from bracket on front shock absorber.
4. Remove front fender splash shield.
5. Disconnect front brake anti-lock sensor connector.
The rear is underneath the rear seat cushion like you said.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-02-2009, 12:47 PM
Ya, I found that same statement under replacement. I was looking in Test.
Thanks
I have an ABS light which codes out to the hyd pump controller and all 4 wheel sensors, I was testing the wheel sensors before changing them. I've already pulled the hyd pump controller.
Q. Are these related, as in; if the controller is bad, it will show the sensors as bad? The 2 in the rear checked good.
