Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-23-2009, 09:52 AM   #1
gonnabok
Unhappy 1995 Mustand V6 won't starts
I have 95 Mustang, V6, 250,000 miles.
When I try to start, it cranks fine, but engine won't start.
It used to crank for 4~5 sec before this happened.
Please help...
gonnabok is offline   Reply With Quote
Old 01-23-2009, 08:39 PM   #2
rhandwor
Re: 1995 Mustand V6 won't starts
Pull a spark plug and install it in the plug wire. Using insulated pliers ground it against the block do you have spark.
If you have spark spray starting fluid into the intake and check if it will start.
After this is done repost results and I can tell you which way to go.
rhandwor is offline   Reply With Quote
