Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-22-2009, 09:43 PM
noclarky58 noclarky58 is offline
2001 Chevy Tahoe Cold Weather Starting Problem
I have a 2001 Chevy Tahoe with a 5.3L engine. Has 137,000 Miles on it. I have it a tune up in August with 133,000 Miles on it (Plugs, plug wires, air filter, coolant check). The problem started this winter when it dips below 35 degree's. The truck won't start. It cranks, and the cranks sound normal speed, and not slipping on the flywheel. I try to start about 10 or so times, and sometimes it will start, but shut right off. If I wait a couple of minutes and go to start again, it will start right up with no problems. The problem starts every time it sits all night, and I go to start up in the morning. I changed the fuel pump in August of 2007, and the fuel filter at the same time since it started stalling on the freeway. Any suggestions would be helpful! I can't take it to a mechanic since I'm a statistic with the unemployed!
Also, the use of starting fluid does not help this problem!
Old 01-22-2009, 11:09 PM
discnik discnik is offline
Re: 2001 Chevy Tahoe Cold Weather Starting Problem
Pull the vacuum line off your fuel pressure regulator and see if there is fuel present. If there is replace the regulator.
Also check and clean your IAC valve and ports.
Just some thoughts.
Old 01-23-2009, 09:26 AM
brcidd's Avatar
brcidd brcidd is offline
Does the security light stay on when it starts and shuts off right away? I've seen two that had security issues that act like yours.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 01-23-2009, 11:08 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Pitch the starting fluid unless you want to blow the dip stick threw the hood.
Only use carb cleaner in spray can for starting aid.
Check for good hot blue spark to all plugs.
Give it a shot of carb cleaner to check for fuel delivery problems.
If it fires on carb cleaner.
Check out fuel pressure.
MT
Old 01-23-2009, 04:52 PM
When it does this, and I try to start, if I crank it for more than 10 seconds, then let go of the key, the security light will come on. This morning it was 38, and it had a little bit of a hard time starting, but after two tries and 30 seconds, it started.
Old 01-23-2009, 07:23 PM
brcidd's Avatar
With the key on ,whether the engine is running or not- the security light should come on and go off within 5 seconds- if it stays on then the engine will soon die- because the security system is shutting down the injectors. This is a big hint. The Passlock II system will need attention- or bypassed.
'99 GMC Yukon
Old 01-23-2009, 07:25 PM
j cAT j cAT is offline
you must check fuel pressure, and it must be 60psi or more...
what was the fuel pump replacement..? if it was airtex then you need a fuel pump...
if you need a fuel pump use only the delphi pump..
do not crank for more than 5 sec. then wait 1-2minutes..before trying again...if you crank too long you WILL damage the starter...
if the fuel pressure is correct it is possible the ECT is telling the computer is warm out...disconnect the MAF sensor and see if it starts...
get the dtc pulled to see if the computer has something to say...
don't forget the fuel filter....got gas in tank? driving on empty will cook a fuel pump fast...
Old 01-23-2009, 07:59 PM
old_master's Avatar
Advisor/Moderator
Originally Posted by j cAT
...driving on empty will cook a fuel pump fast...
???? please explain.
Old 01-23-2009, 10:22 PM
roadrunner2 roadrunner2 is offline
HA ha ha,
I think he got on a roll there.
Good trick to run on an empty tank.
The problem with doing nothing is not knowing when you're finished.
Old 01-24-2009, 10:24 AM
Originally Posted by roadrunner2
HA ha ha,
their are many females that do drive on gas fumes....my sister is one of them...
