Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 01-22-2009, 05:02 PM
eric1h eric1h is offline
block heater anyone?
So, Devin and I went down to work on cars today, and low and behold, my engine was frozen solid!
Looks like the water pump blew a seal and one of the freeze plugs popped.
These cars have been run with straight water so if you live in an area that gets very cold you may want to look into a block heater
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 01-22-2009, 06:19 PM
Cobrafang Cobrafang is offline
Re: block heater anyone?
I prefer a emergency garage heater.
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 01-22-2009, 08:06 PM
NZGTRA17 NZGTRA17 is offline
Well Eric in our (mildish) climate over here in NZ I always looked on freeze plugs as a pain in the butt. I will have more respect for them in future..........!! Hope the plug did its job and there is no other damage.
Kel M
Panoz GTRA #17
New Zealand
Old 01-22-2009, 08:10 PM
Thanks! ME TOO!
I couldn't see any leaks except for the water pump, rad hose and freeze plug, really hope I didn't crack a head or block.
Really suprised it froze. I am in North Carolina for cryin out loud, not green bay wisconsin!
SO much for water wetter, "helping to add antifreeze characteristics"!
Old 01-22-2009, 08:58 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
That sucks... ours came w/ coolant in it.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 01-22-2009, 09:19 PM
Wess-RA's Avatar
Wess-RA Wess-RA is offline
Mine had coolant too and I just drained it (last week) and switched to Distilled water and water wetter. When my car spent the night outside at the track the thought crossed my mind too. Sorry to hear it.
Uwe W.
Panoz GTS
Porsche 996 Turbo
Old 01-23-2009, 08:17 AM
PanozDuke PanozDuke is offline
Man Eric, I feel for you. That's going to be a lot of work. Even though I'm in south central Texas, I think I'll stay with coolant especially since you get some lubrication for the water pump and anti-corrosion properties for the aluminum components. There sure have been some cold temperatures down the eastern half of the country. Praying for minimal damage for your motor.
Mike
Old 01-23-2009, 09:02 AM
Cobra4B's Avatar
I don't really see the point of swapping to straight water or even water w/ water wetter in these cars... it's not like they even get warm on track.
I was seeing 230 oil temps in 100 degree weather at VIR last summer w/ my father and I hot lapping it back to back sessions each time.
Brian B.
Old 01-23-2009, 04:38 PM
It's not so much a cooling issue. Most sanctioning bodies wont let you run Antifreeze. Antifreeze Plus asphalt = ice slick! yes, straight water cools better than AF, but its mainly a safety issue. That's probably why the RA cars had AF in them and the WC cars did not.
Now for the good news....
I went over today and replaced the water pump, freeze plugs and the upper radiator hose. Luckily it warmed up here and was near 60 today so filled the car up with a 50/50 mix and fired her up. Fingers, legs, toes and eyes crossed. and the motor appears top be fine. No smoke, no knocks, no foam or froth in the oil pan, and most importantly, no leaks!! so i will leave the AF in the car until spring and then drain it back out when i finish the LS1 swap.
Old 01-23-2009, 05:01 PM
David Eastman David Eastman is offline
The school cars had anti freeze in them because they were kept out side with covers on.
David
Old 01-23-2009, 09:45 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
But he did not start mine.... :o(
Really, I am glad it turned out as good as it did. someone was looking out for you this time around - if it was the bimmer, gawd know's......
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
