Ignition switch problem???
i have a 1994 pontiac grand prix 3.1 and it wont start sometimes..it has 203k. i just put a new starter in it and had the alt and batt tested all good. but sometimes when i turn it off and go to start it it wont do anything no click no nothing, but i have full power lights, radio, ect. it starts when it wants to.
Re: Ignition switch problem???
attempt to start it in nuetral next time it doesnt start. If it starts, then you might need to adjust or replace the PRNDL switch. Do your backup lights come on when your in reverse?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
no it doesnt start in neutral either.. and i havent checked on the reverse lights.
Ok, then your ignition switch is probably the next logical step.
where is the ignition switch located??
Not sure I would jump right into replacement of the ignition switch without a few tests.
Have you checked for b+ on the starter S terminal while an assistant attempts to start the car?
no i havent ... how can u tell if the switch is bad?
how do i...
know if my ignition switch is bad?? how do i test?
Re: how do i...
To start do you have any GM wiring diagrams of your specific year and model GP?
no i dont
See if when you turn the key to the start position you have voltage at the yellow wire on the ignition switch. The red wire is the main hot to the switch.
see thats just it.. i dont know where the ignition switch is
steering column. But you might be able to access a big electrical cluster plug in the drivers side kick panel for test purposes.
yea one end of it is under the dash.. but i dont know how to go about testing
