Odometer
I have a 1991 chevy caprice 5.0 sedan, the odometer has stopped working and i was wondering what would cause this and how to fix it and where to locate the parts that need fixed
thanks |
Re: Odometer
Re: Odometer
The speedo works fine but the odometer or trip odometer DO NOT work
Re: Odometer
this is digital or mechanical ? |
Re: Odometer
The Odometer Does Not Function Period. It Is A Mechanical Odometer And Trip Odometer. Therefore It Does Not Rotate/change Which Indicates Something Has Broken
Re: Odometer
Re: Odometer
Sorry, Everything on my dash is mechanical, from the speedometer to the odometers but like I said the speedo works fine its just the odometer and trip meter that are not changing and I havent inspected anything becuase i dont know what to look for
Re: Odometer
report what you found... |
Re: Odometer
is there an odometer gear or anthing on the transmission that would cause this?
Re: Odometer
BTW be careful with the instrument cluster once you remove the front plastic thing because the needles sometimes tend to be really delicate and can break easily.
![]() ![]() ![]() '83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now. -- 65,000 original miles --
Re: Odometer
Maybe its rusted stuck?? I'm just taking a guess there. Only reason i say this is because on my caprice i would keep hearing this ticking noise and i found out it was my odometer every time it changed because it was rusty. All i had to do was spray some WD-40 up between the trip odometer button. Take caution if you do this because it could spray inside the cluster and you'll end up having to take the clear plastic thing off to clean the grease off.
BTW be careful with the instrument cluster once you remove the front clear plastic thing because the needles sometimes tend to be really delicate and can break easily.
