Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-21-2009, 11:40 AM
4runner Freak 4runner Freak is offline
85 Caprice rear end replacements
A friend of mine blew his rearend up in his '85 Caprice and I'm trying to help him replace it.
I am a Toyota junky(4x4) and know nothing about his Caprice.
What vehicles had the same rear axles?(years and models)
I don't know what gears came stock in these either, and would like to know.
I am trying to help him source one now and would like to know what other vehicles to look for.
Any online FSMs floating around for the '85 Caprice?
I believe the Buick Roadmaster is the same as the newer Caprice, but wasn't made in '85.
What years of Caprices will swap over?
So far I found these models are similar, but I don't know if the rear axles are the same.(Can anyone verify?)
1977-85 Buick LeSabre
1977-90 Buick Estate
1977-90 Oldsmobile Custom Cruiser
1986-91 Oldsmobile 88
1982-86 Pontiac Bonneville
Sorry for the total Newb questions.
Thanks for any help.
Old 01-21-2009, 12:55 PM
j cAT j cAT is offline
Re: 85 Caprice rear end replacements
[quote=4runner Freak]A friend of mine blew his rearend up in his '85 Caprice and I'm trying to help him replace it.
you will find that this axle is very common and used in many GM vehicles...this rear diff has few problems and the scrap yard should have one for you for a good price...
Old 01-21-2009, 01:59 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
GM B-body sedan with 7.5" ring gear, used 1977-1990 (also 1991-1996 but the wheel bolt pattern is different).
The wagon unit won't properly fit, so get one only from a sedan.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-22-2009, 10:41 AM
Are they linked rear ends or leaf springs?
Are the 77-90 rear ends all linked or leafs also?
Thanks for the help
Old 01-22-2009, 10:49 AM
Scrapper Scrapper is offline
AF Premium User
should have coil springs back there. i can see leaf on a truck but not your going to do on the car.
