Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-21-2009, 09:49 AM
Rmasters3 Rmasters3 is offline
P0116 ECT Circuit Range/Performance CEL Help
I'm getting this code from a CEL light scan. 2004 Rodeo w/3.5 direct injection. The Autozone store said their scanner shows "Coolant Temp Range". I'm guessing it's the coolant temp sensor (edit: I replaced the CET sensor- P0116 returned.)
This truck has always rev-ed high and lingered on high on any cold start. It's has worsened lately with the recently added dimension of a start up cold idle that revs then slows and revs again.
Thanks
Old 09-17-2010, 11:58 PM
rod2004 rod2004 is offline
Re: P0116 ECT Circuit Range/Performance CEL Help
Thanks
carbon in engine?
2004 rodeo 3.2L 2WD
AISIN AT
http://www.isuzufaq.com/
http://forum.planetisuzoo.com/
http://isuzuforums.com/
Old 09-18-2010, 05:27 AM
carbon in the engine removed twice and finally it turned out to be a fauly catalytic converter--which apparently was causing the carbon problem
Old 09-23-2010, 09:30 PM
oh, I've learned something new. Thanks
2004 rodeo 3.2L 2WD
AISIN AT
