Old 01-20-2009, 10:25 PM
Forscythe87 Forscythe87 is offline
Vibration
New problem! Im getting a pretty hard vibration when the car is in gear (D)(OD)(1)(2). I'm thinking it may be bad motor mounts but want some other suggestions before I get arms deep in it. The whole car seems to shake.
1998 Chevy Lumina LS 3.1L 126K Miles
Old 01-21-2009, 07:19 PM
maxwedge maxwedge is offline
A990 racer
Re: Vibration
many things can cause this, without a road test only guesswork is suggested, a engine misfire can cause this a tire with a belt shift, bad axle joint and much more.
Old 01-21-2009, 10:47 PM
Re: Vibration
Im going to hook up a code reader and see what I get.
The vibration only happens at a standstill. Not sure if its related to the recent cold weather...
Old 01-21-2009, 10:52 PM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Re: Vibration
Max is right. Does this happen only at a stop or also when driving?
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 01-21-2009, 10:58 PM
Bearwulf's Avatar
Re: Vibration
This only happens in gear? Is check engine light on?
97-Lumina LS
Old 01-21-2009, 11:24 PM
Bearwulf's Avatar
Re: Vibration
Try unplugging the TCC solenoid, then putting in gear.
97-Lumina LS
Old 01-22-2009, 01:53 AM
Re: Vibration
Yeah only in gear. Only while stopped. No check engine light. Ill unplug the TCC and see what happens.
Performance seems to be normal.
