Old 01-20-2009, 08:59 PM
wantabe wantabe is offline
grand prix overheating
i am at witts end with this car i have the 3.1 3100 just replaced the water pump, thermostat. heater core and i replaced the intake gaskets twice and this thing still wants to get hot gets hot then rods start chattering then it dies i can not figure this thing out
Old 01-20-2009, 09:10 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: grand prix overheating
Has the cooling system been flushed? Is there air in the cooling system that needs to be blead out? Is the head gasket blown? (stupid question) but is the t-stat in in the correct direction? Do the cooling fans turn on?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-21-2009, 02:02 AM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
yeah, i would say head gasket. 3100's are known for em'.
Old 01-21-2009, 06:10 AM
CrazyHorst CrazyHorst is offline
It also sounds to me like you have blown out a headgasket from the combustion chamber into the water jacket.
This will boil the coolant internally (~800 psi peak cylinder pressure vs. 50 psi maximum pressure in the water jacket).
Also keep in mind a 3100 has iron block and aluminum heads which tend to "scrub" the head gasket into failure (over a long period of time) due to the different expansion rates of the metals.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 01-21-2009, 07:20 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I'll add myself to the list of people that believe you have a blown head gasket.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-21-2009, 09:40 PM
ok guys thanks alot looks like a tear down is the ticket thanks again
