Old 01-20-2009, 09:19 AM
canadaga canadaga is offline
98 Cavalier cannot start cold
My 98 Cavalier (4cyl) has problems starting when it is cold. It's -15C outside and the car won't start if it sits overnight. The starter cranks the engine but it just won't catch. If I pump the gas while the car is cranking, I can eventually get it going. Weird! Please help!
Old 01-20-2009, 09:41 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: 98 Cavalier cannot start cold
Ever let your gas tank get below 1/4 tank a lot? Get some gas water remover. I bet you have some condensation/water in your fuel lines cause them to freeze over. Typical winter issue.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-21-2009, 06:36 AM
Ok, I'll give that a try. The fuel rarely gets below 1/4 tank before I fill it up. Hopefully it is that simple...
Old 01-21-2009, 03:12 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Could be the coil packs, fuel injectors not spraying finely enough, or you could just need a tune up. If I were you, I'd just install a magnetic block heater... $35, the car's almost guaranteed to start, and it's kindda-sortta warm right away.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-21-2009, 03:58 PM
Scrapper Scrapper is offline
AF Premium User
sounds like a fuel pump because when your triying to start it the starter takes away alot of juice from the fuel pump. can you hear fuel pump go zip when you just turn the key to on and not start it? if you don't hear tha zip i would have fuel pump tested if you don't hear the zip until it go's to engine.
good luck.....
