Old 01-20-2009, 01:51 AM
tempfixit tempfixit is offline
94 clutch pedal switch
94 doesn't want to start unless clutch pedal is pressed all the way to the floor board, is there a adjustment on this switch? Buddies truck so I haven't looked at it yet.
Thanks for advice
Old 01-20-2009, 12:29 PM
Scrapper Scrapper is offline
AF Premium User
Re: 94 clutch pedal switch
i have to have to push my clutch to the floor before i can start mine. it's for safety you wouldn't it to start in gear do you?
Old 01-20-2009, 06:44 PM
I understand the safety issue, just asking if there is a little adjustment so you don't have to push it so hard that you think it's going to thru the floor board. Gear shift lever should be in neutral not in gear when starting to begin with.
Old 01-21-2009, 12:04 AM
Davescort97 Davescort97 is offline
Escort guy
I'm sure there's some adjustment available. My Escort has the same thing and there is a litltle black box with a plunger coming out of it. If you don't want to be bothered anymore with it there is 1 wire running into it and 1 wire running out of it, so just scrape some insulaton off of the wires and run another wire around the switch. I agree. It's not needed. I bypassed mine in the possible scenario of being stalled on a train crossing with a train coming and not being able to get if off the tracks with the starter.
Old 01-21-2009, 09:04 AM
Thanks for info Davescort97. I check it out.
