Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-19-2009, 09:07 PM
CrazyCritter07 CrazyCritter07 is offline
question about my 95 caprices
I have a 95 caprice classic, looking for someone with more knowledge then i, about the rear end of my car(if thats whats wrong). when i drive my car it makes a hum sound. when i let off the accelerator the noise goes away. i did check and changed the gear oil but i really had know idea what i was looking at. if anyone has some pointers or suggestions please let me know thanks.
Old 01-20-2009, 07:20 AM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Re: question about my 95 caprices
I'm not very knowledgable on this kind of stuff either but if i remember correctly i think this means your bearings in the rear end are bad.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 01-20-2009, 09:09 AM
j cAT j cAT is offline
the noise is refered to as a whine...as the differential ring and pinion ring wears this noise will get more noticable...your discription is drive noise...
replacement of the diff oil and use of the correct type is important,,,If you have a limited slip diff this oil needs frequent replacement...when checking your level every engine oil change look at the oil quality as well as level ....if its getting dark remove rear cover clean and replace oil...
how often do you service the diff.?
Old 01-23-2009, 06:50 PM
i did just change the oil in my rear end and cleaned it very well but the whine is still there. i have put about 7000 miles on it in the 2 years i've owned it and this is the first time i changed the oil in the rear end. i have no idea when it was looked at or changed before me.
Old 01-23-2009, 07:04 PM
well that sounds good....remember if you do live in a very cold climate the oil when below 20degf will cause the rear diff to make noise until it warms...
by replacing this diff oil you should be ok as it takes alot of miles to wear out the gears with frequent servicing,,,
how much dirt/debris did you find in the diff when you serviced it...?
Old 01-23-2009, 07:42 PM
it wasnt dirty at all it was just black oil. i do live in MN it does get cold but even when its warm out it still is loud.
Old 01-24-2009, 09:40 AM
that sounds good it seems, the gear oil was never replaced, as over time it does get very dark ,,,I have seen black...but not in a small vehicle as you have....I think because you found no metal particles it should last many more miles...just check for fluid condition every oil change....
Old 01-24-2009, 09:46 PM
ok thanks but you think my caprice is small?
Old 01-25-2009, 09:49 AM
I have worked on much larger vehicles and if the oil gets low with the large loads the oil will turn black and smell very bad..
