Old 03-23-2003, 07:40 AM
AirbagsOnDaHonda AirbagsOnDaHonda is offline
Send a message via ICQ to AirbagsOnDaHonda
Hatch w/ LS Swap
I bought a 92 SI a few days ago and it already has an LS swap. The guy I bought it from put an MSD ignition and blaster coil on it, and advanced the timing also. He told me I should only put 93+ octane fuel in it, b/c of the advanced timing, etc. but if I was to retard the timing a bit I could use a lesser octane. Should I only use Super in it, or do you guys think it is safe to use Premium too, b/c gas is REALLY expensive and this bad boy guzzles it!
Old 03-23-2003, 07:55 AM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
The only thing I would put low grade gasoline in is my lawnmower.
Old 03-23-2003, 10:18 AM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Re: Hatch w/ LS Swap
I never thought I'd here that from a Honda driver.
Old 03-23-2003, 12:10 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
set the timing to 0 degrees and run 91 octane
Team Lonely Drivers
Old 03-23-2003, 04:42 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
something has to be wrong if it guzzles it, I have had an integra before
94 rs with the same engine you are talking about (B18B) you masy have the B18A but i dont know, anyways, the I/H/E cou;ld have done it but i was on the gas all the time and still got great mileage.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 03-23-2003, 08:07 PM
o2 sensor the problem?
I found out that the o2 sensor is not connected, the wires have been cut. Could this be the reason for the horrible gas mileage? Also, how would I go about reconnecting the sensor, is it just a plug-and-play type deal or do I have to do a lot of work to get it where it needs to go? Thanks a lot guys!
Old 05-29-2004, 12:10 AM
simplypinoyy simplypinoyy is offline
Send a message via AIM to simplypinoyy
Re: o2 sensor the problem?
Yes that could be y because the O2 sensor I hear changes how much fuel is sent to the motor if its not connect then the ecu will send a preset amount of fuel which would cause u to run a little rich.
Old 05-29-2004, 11:44 AM
jameskersten jameskersten is offline
the o2 snesor reads yor exhaust gases and tell the ecu how much fuel to pump,hense poor gas milage, if its not hooked up it will go back to either a preset amount or on some cars it will go back to the amount it was at when it last worked. so if it teh o2 died at startup,good chance your gonna run rich,on the highway at full warm, could run lean.
as for the octance you should use, set your timing to 0 (i believe 14degrees) and run manufactures rec. which is midgrade on that motor i believe. higher octance gas isnt needed on a basically stock honda motor. its harder to burn higher octance fuel, which isnt needed for a 1.8 motor that is stock.
1993 honda civic si -turbo charged b18c1
dynoed: 316whp at 11lbs
