Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 01-19-2009, 07:19 PM
98 venture 98 venture is offline
Nut in intake
Hello, I was taking the alternator bracket off the bottom bottom manifold when i dropped the nut in it. Is there a way to get it with out taking the bottom manifold off? I was putting the damn thing together after a head job and left the stud and bolts on top. When i was going to take the nut off of the stud to put the alternator bracket on it fell in. Please tell me it can be retrieved with out taking the lower intake manifold off again.
Old 01-19-2009, 11:51 PM
discnik discnik is offline
Re: Nut in intake
Do you have a flexable magnet ? And hope the valve is closed or it just may have ended up in the cyclinder.
Best of luck.
Old 01-20-2009, 12:00 AM
Re: Nut in intake
Originally Posted by discnik
Do you have a flexible magnet ? And hope the valve is closed or it just may have ended up in the cylinder.
Best of luck.
Thanks for replying. Yes I have a flexible magnet. If the valve is open and it goes down to the cylinder how far do i need to go back down?
Old 01-20-2009, 12:17 AM
Re: Nut in intake
If it is a fairly large nut, ALL THE WAY, to the cyclinder. If not it can cause damage to your piston, valves, & push rods.
If it is in the cyclinder you may get lucky by removing the spark plug and go fishing.
Again Good Luck !
Old 01-20-2009, 09:20 PM
Re: Nut in intake
Well, I took the lower intake off and there it was. It was in the cylinder head on top of the valve, boy was I lucky. I was already thinking worst scenario, having to take off the head(s). The funny thing is that I dropped the nut in the back left corner of the intake and I found it in the front cylinder head.
Old 01-20-2009, 11:18 PM
Re: Nut in intake
Man with that kind of luck I would have went and bouhgt a lottery ticket !!!!
Old 01-21-2009, 12:17 PM
roadrunner2 roadrunner2 is offline
Re: Nut in intake
Wow! Good job. That could have done a LOT of damage had you started it up.
The problem with doing nothing is not knowing when you're finished.
