Old 01-19-2009, 07:27 PM
Captain Mark's Avatar
Captain Mark Captain Mark is offline
Question on airbrushing primer
Hi all,
Has anyone here had any luck decanting and airbrushing primer? Or are there bottled (perhaps pre-thinned) primers on the market at all?
I'm just getting tired of drenching kits in high pressure blasts of primer, and decanting automotive or tamiya primers into my airbrush just glues up the airbrush.
I'd prefer the accuracy and control of an airbrush, but I've not found a suitable primer which doesn't gum it up completely. Can anyone offer any advice here?
Oh, and I've tried thinning the primers with all kinds of things, no luck.
Cheers,
M
EDIT: I just found some on hiroboy.com , the Zero Paints brand. Anynoe used this before and can comment on it either way? I've not got any experience with Zero Paints.
Old 01-19-2009, 07:57 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Question on airbrushing primer
I would guess that decanting Tamiya primer would work fine- but I haven't tried it. Gunze Mr Surfacer works well out of an airbrush.
My personal favorite is Evercoat Dura Build grey acrylic primer. But you need to thin it 1:4 with Evercoat's VOC reducer. But a quart of primer and a gallon of reducer is a bit of a lifetime supply....
PHOTOBUCKET SUCKS
Old 01-19-2009, 08:21 PM
360spider's Avatar
Hiroboy sells variety of airbrush primers.
Old 01-19-2009, 08:46 PM
935k3's Avatar
935k3 935k3 is offline
Alclad makes their own pre-thinned primer that is very fine and is light grey in color. I especially like it for priming all of my smaller parts. It comes in a 4oz bottle for $8.99 at my local hobby shop.
Old 01-20-2009, 08:56 AM
TRBJ TRBJ is offline
Send a message via MSN to TRBJ Send a message via Skype™ to TRBJ
alclads micro filler is veery fucgin hard to open!! or may be it only happen to me?
Old 01-20-2009, 09:06 AM
sportscars24's Avatar
sportscars24 sportscars24 is offline
@Captain Mark
I always use Model Master Gray Primer it works for real car colors on plastic and also it works with Zero Paint colors.
Old 01-20-2009, 12:56 PM
cyberkid's Avatar
cyberkid cyberkid is offline
I've personally use all Tamiya's and Gunze's primers without any trouble at all... both brands have primers in cans and bottles.. (I haven't tried Tamiya's in a bottle yet). I decant most of the time except when I'm too lazy :P
As for primer gumming up your airbrush.... that really sounds strange... a few Q's:
1.Have you stripped your AB for a total clean out recently?
2. What brand(s) primer are you using and what ratio are you thinning it at?
3. Have you tried decanting straight into the AB cup and shooting more or less right away?
As for the Zero primers, I just got some and I'd say they're just as good as his normal base color paints... goes down well, dries very fast. Just would suggest that you place a clean marble in the jar to help mix up the pigments when shaking, this goes with any decanted paint (Zero's recent products have 1 included)...or a VERY good stir.
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 01-20-2009, 01:52 PM
CFarias's Avatar
CFarias CFarias is offline
I don't know if they sell this where you are but I switched to the Duplicolor Paint Shop system:
http://www.duplicolor.com/products/paintshop.html
There BSP100 Gray primer has a very forgiveable thinning ratio, and I can shoot from 25 to 35 psi with it. I thin it with 3 parts acetone and it goes on very thin but tough.
Old 01-20-2009, 03:06 PM
Didymus Didymus is offline
I always use lacquer thinner to thin decanted Tamiya lacquers at a ratio of about 1:5. I spray Tamiya primer straight from the can with no problem, so I'm a little surprised you're having trouble with it. But seems like lacquer thinner ought to work.
Yesterday I was surprised when I tried to remove some Tamiya primer with 99% isopropyl alcohol. It took some rubbing; the alcohol didn't easily dissolve the primer like it does regular TS-series paints. Maybe the primer has different chemistry.
Ddms
Old 01-20-2009, 06:31 PM
JimboCO JimboCO is offline
I routinely decant Tamiya primers and thin them with either laquer thinner or Mr. Color thinner. Never had a problem. Like others have mentioned, check yopur thin ratio and clean your brush. The extra hassle in decanting/thinning is way worth it in my opinion and really isn't much of a hassle at that.
Good luck!
Old 01-25-2009, 01:08 PM
jasolbes jasolbes is offline
My personal choice has been (for more than 20 years now) DuPont's Universal Primer (Value Shade) #'s 41SM (white), 44SM (light gray), 47SM (dark gray). This primer is intended to be used for acrylic lacquers, I apply it with an airbrush (30/35 psi), it's harmless on Tamiya and Fujimi plastics and protects it from acrylic lacquers. Hope this is of any help.
José Antonio (México)
Old 01-25-2009, 01:35 PM
Lownslow's Avatar
Lownslow Lownslow is offline
anyone know the thin ratio for MR surfacer 1000
Old 01-25-2009, 02:51 PM
MPWR's Avatar
WTF is a 'thin ratio'??
You thin until it sprays well, and you verify it by test spraying.
MR Surfacer requires A LOT of thinning, but it's impossible to thin it by ratio. Every bottle will take a different amount of thinner, depending on how old it is, how it has been used, etc. It's a moving target- so you thin until it sprays best.
PHOTOBUCKET SUCKS
Old 01-26-2009, 03:54 AM
custanius custanius is offline
I decant tamiya light grey primer, they always work for me, I either increase the pressure slightly or thin it with Mr. Thinner if pulsation appears, which can happen from time to time. Btw, I always run some thinner through the AB prior to putting the actual primer through. Dried up paint, even minute amount can cause clogging.
Old 01-26-2009, 11:13 AM
Back in ancient times, I was happily using SEM high-build automotive primer on resin models. Expecting no problems, I sprayed a Gunze Sangyo body with the stuff, and it etched the heck out of the surface, destroying the model. (I've heard since then that Gunze plastics are - or were - more easily damaged by some chemicals.)
So I've stuck with Tamiya primers ever since, despite the higher cost.
Information like Jose's is very useful, but if you're using unknown products on models, test, test, test! And that applies especially to automotive products, which have gotten more and more exotic because of environmental regulations.
Ddms
