Old 01-19-2009, 06:34 PM
reefgeorge reefgeorge is offline
2002 Blazer window leak and wind noise
The drivers door on my 2002 Blazer was leaking water at the top over the window switches so I replaced the very top large seal that spans both driver side doors and goes down the windshield edge. Now I have a horrendous wind noise there which is corrected by pulling in the top of the door from the inside or taping over the new seal from the outside. It is interesting that a new seal started this when the old one was partially falling off and deteriorating.
1) I noticed that there is no guide track/rail for this top seal as you round the corner and start down the windshield edge. Is there a trick/technique to setting this seal here such as pulling it tight as you round the corner? This appears to be the problem area.
2) I see that my pins and bushings are breaking down so I will replace those. Is that likely to help?
3) I note like a previous poster that my door bulges out at the top so I will try to torque it back in (yikes!). I may have to start drinking again first.
4) Unlike the passengers side, the drivers door sits lower than the back door (sighting down the roofline) but is square in the opening. The door has to "climb" the strikeplate when closing) Is that all pins/bushings?
5) I also notice that when the door is closed and latched it is looser than the others (I can push it in and out against the door frame catch pins a fraction of an inch). Is there a way to tighten up the door when closed (new catch plate or door latch or an adjustment)?
6) Lastly, is it possible that the inner seal that completely surrounds the door opening also needs to be replaced? Perhaps the new outer seal is standing the door off of the old inner seal?
Thanks,
George
Old 01-19-2009, 06:48 PM
old_master's Avatar
Advisor/Moderator
Re: 2002 Blazer window leak and wind noise
Replace all worn door hinge pins and bushings, that'll probably fix all of your problems. Most auto parts stores have the repair kits, (made by Dorman in the HELP! line). There's a thread, with pictures, in the Blazer "How-to" section.
Old 01-19-2009, 07:30 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Old Master is right, replace the door pins and bushings. And also lubricate them and all other hinges such as the hood and hatchback with a light oil every time you do an oil change. My 1950 GMC truck manual mentions that service stations often overlook lubricating body parts, but they are part of the scheduled maintance.
If you do it yourself have some help ready, those doors are heavy. Link to DIY is here: http://www.automotiveforums.com/vbul...d.php?t=363334
As far as adjusting the gap when closed, look at the the striker post. It should have a star type torques reciever in it that will allow some adjustment but replace the worn parts first.
Old 01-24-2009, 08:08 PM
Based on the advise here I tried to tackle the pins and bushings first. I could not get the hinge spring out with the compression tool. Can someone give me some guidance here?
I was trying to remove the spring with the wire harness and weather boot still in place so that limits the angles that I have available for the compression tool. Is that the issue? Also, I could not get the tool over either of the spring ends, only a few spring turns in on both sides so the spring does not get compressed enough to come off. Others have referenced using a pry bar or screwdriver for at least the removal part. Where do you apply the leverage?
For whatever reason, I cannot see the pictures embedded in the sticky posts on this subject for guidance on the spring removal portion.
The tools all seem to be the same but here is the exact one that I bought in case my version is hosed:
http://www.tooltopia.com/index.asp?P...OD&ProdID=4977
Thanks,
George
Old 01-24-2009, 09:10 PM
old_master's Avatar
Advisor/Moderator
That's the correct tool. No need to move the harness or weather boot. You have to insert the spring compressor in the second winding in from each end of the spring, then compress the spring all the way, then finesse the spring out. Once you get the hang of it, it's easy.
Old 01-25-2009, 09:59 AM
Sounds like I was on the right track. Maybe the spring can be in just the right rotation so that the tool cannot get far enough into the spring (most of the time the tool kept popping off). I'll check it out and try again. Does the tool need to be finessed in or pounded in? Anyone else know where I might be going wrong? This spring has humbled an otherwise mechanically inclined DIYer.
Thanks,
George
Old 01-25-2009, 01:46 PM
old_master's Avatar
Advisor/Moderator
Adjust the jaws and just kinda wiggle-slide it in.
Old 01-28-2009, 07:37 PM
An interesting update. As I said in the original post, I replaced the top drip channel at the top of the driver door and a severe wind noise was added to the water leaking. I noticed in the repair section of my new Alldatadiy subscription (which is great) that it says to apply that new drip seal in 80 degree + conditions which I definitely did not do. We had near record breaking cold weather (Florida) that day. Well yesterday I noticed that the wind noise was spontaneously gone after a week of daily whistling. I looked up at the outdoor temp display and it was - you guessed it, 80 degrees outside. I just hope that I am still in good shape after I shift the door position with the hinges and pins which I will tackle as soon as I master the spring removal. I am now equiped with a replacement spring so that I can get the hang of the tool out in the open.
George
Old 02-18-2009, 04:56 PM
Still struggling with the spring, bought a spare one to experiment with. Looks like the spring can be in just the right rotation so that you cannot get the tool inserted far enough in to get a good "grip" which may be my problem. Is this the correct insertion point/orientation?:
http://www.geocities.com/ggidzinski/Blazerspring.html
Thanks,
George
Old 02-18-2009, 05:50 PM
old_master's Avatar
Advisor/Moderator
That's the correct positioning of the tool, but you need to compress the spring until the windings of the spring are touching each other. Use caution as to what direction you point it, if it slips out, hopefully all it will do is scare the daylights out of you and not damage anything.
Old 02-19-2009, 11:22 AM
Thanks, I'll give it a try this weekend and report back. It looks like my problem is that about 20% of the possible spring positions (rotation) make the proper insertion of the tool impossible, at least with the boot and wiring harness in place. Hopefully it can be rotated in place before insertion of the tool and removal. If not, the harness and boot will have to come out first.
To your point I did compress the trial spring all the way and it looks like a weapon. I now see the reason for all of the "towel" suggestions. You definitely need to be careful where you point that thing.
George
Old 04-02-2009, 05:04 PM
Replaced the pins/bushings and that did the trick. Fixed the wind noise and leaking.
Anyone know how the the door strike plate for the latch is backed up behind the torx bolts in the center post? Is it a welded nut/threaded frame or is there a loose bolt/plate that will fall into the center post when the torx bolts are removed?
Thanks,
George
Old 04-02-2009, 06:56 PM
old_master's Avatar
Advisor/Moderator
Not sure George, I've never taken the striker all the way out to find out. Maybe someone will chime in that knows for sure.
You have to know how it works,
to figure out why it doesn't.
Old 04-02-2009, 08:33 PM
b1lk1 b1lk1 is offline
It makes no logical sense for the bolt/plate to not be attached to the pillar in some manner. The latch post is attached to the pillar AFTER the body is build so there would be no access behind it in theory.
Old 04-03-2009, 03:49 AM
That makes sense to me but as I lossen the torx bolts it feels very loose back there.
George
