Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-19-2009, 10:21 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Higher Amp Alternator
Hi Guys, My friend asked me to do some research for him.
He's got a 2003 Chev Tahoe 5.3 V8
He's got it filled with a lot of electronics (HID's, Deck, AMP, Subs.....) and he says that the stock alternator can't handle everything he's got. In fact he unhooked his amp untill he can get a High Output alternator.
So, My question, Anyone know of any good places to buy a HO alternator?
Or is there anything he can do to his charging system to boost his amps and keep his headlights from dimming?
Thanks!
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-20-2009, 01:46 PM
j cAT j cAT is offline
Re: Higher Amp Alternator
first off what is the load he is driving? this would determine the alternator required...or just guess at it...
because this load is unknown it would be best to locate in your area an electrical automotive shop that has the ability to determine what his needs are then modify the vehicle to allow the proper sized alternator..
be advised this just don't pop in ....its expensive but its better than buying alternators often..
Old 01-26-2009, 02:12 PM
BIIG PIIMPIIN's Avatar
BIIG PIIMPIIN BIIG PIIMPIIN is offline
I've just purchased a 200 amp alternator off eBay for my truck. Do a search for "200 amp" and make the purchase. Think about ambulances, and how much power output they require... lights, sirens, medical equipment. Those rigs use a 200 amp alternator. Should be more than enough power for your friends ride. Also, might consider a cap for the stereo system. Puts a little less strain on the charging system.
Old 01-27-2009, 03:13 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
BIGPIMPIN may be onto something. A higher output alternator may be what he needs along with a cap(acitor) to help even out the draw his stereo makes on the alternator. But I'll also side with jCat suggesting getting the pros involved. Those caps store alot of energy and can to serious damage (and injury) if not installed correctly.
For a base setup it's a pretty simple calc: Volts x Amps = Watts
12 x 120 = 1440
I don't know how much the truck itself requires, but any serious stereo can easily eat up most of that output with only a single amp or two. Add to the fact that most alternators don't provide their full power at engine idle, which is usually you're cruisin' speed. Bigger alternator, cap(s), and possibly a deep-cycle battery would be good investments. Talk to a stereo pro for the details & to be safe.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-27-2009, 03:51 PM
perhaps you can give us your install recomendations,pulley /belt and other componets that need be changed to allow the physical installation of this alternator..and the engine year etc...
Old 01-27-2009, 03:55 PM
Originally Posted by jdmccright
I don't know how much the truck itself requires, but any serious stereo can easily eat up most of that output with only a single amp or two. Add to the fact that most alternators don't provide their full power at engine idle, which is usually you're cruisin' speed..
my 2000 silverado with the a/c on and lights requires 66amps...I have measured this several times....this is with a fully charged battery at operating temp...no high current noise makers installed...
