Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 01-19-2009, 12:44 AM
fenwick2 fenwick2 is offline
sticky transfer case ? please help
When I disengage four wheel drive the hand lever goes down easy and the light on the dash
goes out but the T case maintains engagement. As I begin to drive again and reach about
30mph the T case disengages with a thunk (audible and felt through frame).
Is there anything (external or in linkages) that can be adjusted to remedy this problem?
I thank you in advance for your time and knowledge. fenwick2 01' Wrang 2.5L 5spd
Old 01-20-2009, 08:52 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: sticky transfer case ? please help
When it disengages like that, are you on a hard surface road?
Disengagement can be difficult, unless you're on a surface that allows some slippage of the tires....the system can bind up, holding it in 4wd.
Another thing to make sure of, is that you have the same size/make/wear of tires, and that they're inflated to the same psi. If the tires are different sizes they can cause the same binding. Even tires of the same size, but different manufacturers, can be different enough to cause issues.
If those don't solve the issue, it could be a linkage or transfer case alignment issue.
Check the tires/inflation and post back. Hope that helps.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
