Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-18-2009, 05:06 PM
Roflmao Roflmao is offline
96 eclipse engine problem
I recently bought a 96 eclipse. It runs fine except that the engine shakes when the car is stopped. The guy I bought it from said something like the second cylinder head needed to be replaced and that it would cost about 400, does that sound about right because I'm thinking it'll cost more than that
Old 01-18-2009, 05:28 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 96 eclipse engine problem
Welcome to AF!
Which motor are we talking about first? GS/RS = 420a or GST/GSX = 4g63. Is it stock? Are there any noises when it's shaking?
Bad motor mounts can cause it to shake. Check if the rubber in the mounts (all 4 of them) are damaged or even missing.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-18-2009, 08:10 PM
It's a 420a stock, and I can hear it squeaking a little, rubber mounts are good
Old 01-19-2009, 12:14 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Second cylinder head? There is only one head for all 4 cylinders, just so ya know...
Even if the rubber mounts are there and look ok, it's quite possible for them to still be bad. They get slight tears in them from the rubber just getting old and not holding up to the stress of the torque. To me, it sounds like the motor mounts just need to be replaced with some new OEM ones. Or you could even upgrade them to polyeurathane ones and they will last forever practically...
Did the previous owner give you any other indications as to anything else that could be causing this problem? I personally think it is still a bad motor mount somewhere, but I suppose it always could be something more serious. However, if you say its running fine aside from that then I really doubt there is any kind of damage to the head. The thing would be running horrible if at all if the head needed replaced.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-13-2009, 10:22 AM
Bodack Bodack is offline
Send a message via AIM to Bodack
No, that doesn't sound right. Do the RPMs jump, stay solid, fluctuate? If so check for vacuum leaks then go from there. +1 for checking motor mounts as well.
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
