Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-18-2009, 04:00 PM
Pontihog Pontihog is offline
99 suburban idling high
Hi,
My 99 burb has been idling high as I slow down lately. After coming to a full stop, I can throw it in neutral and the tach is at 1500rpm and then comes down to 500-600 after about five seconds. I notice the rpm staying higher as I am coasting towards red lights or stops.
No check engine light.
Any help will be appreciated.
Thanks
Ponti
Old 01-19-2009, 06:11 PM
j cAT j cAT is offline
Re: 99 suburban idling high
Originally Posted by Pontihog
Hi,
Thanks
Ponti
this is a common problem...the IAC and throttle body need cleaning.....with a tooth brush and throttle body cleaner [NO CARB CLEANER]
remove the carbon build up...since you will be removing the air ducting this would also be a good time to clean the MAF sensor with CRC MAF cleaner...I'm sure you will find the engine will run better....the IAC is held in place by 2 screws at the side of the throttle body...do not try to rotate the IAC just clean it gently with the soft brush and cleaner....spray into the hole also....inside is a seat make sure its clean...
Old 01-22-2009, 06:17 PM
Thanks,
That took care of the problem.
Ponti
