Old 01-18-2009, 02:29 PM
crazyduetoiowa crazyduetoiowa is offline
Send a message via AIM to crazyduetoiowa Send a message via Yahoo to crazyduetoiowa
2000 2.4 misfire
Hello I have a 2000 z24 2.4 and when its idling it recently started what i think is misfiring. It will idle fine then cut out for a sec. It appears to only do it when its idling. Should I start by replacing the coil packs?
Old 01-21-2009, 02:52 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 2000 2.4 misfire
I would start with diagnosing the problem, but the ol' throwing parts at it will eventually get you there too. Check the resistance of the coils, but a bad coil would probably not be just at idle. How long since a tune up? What's the fuel pressure? Any codes?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
