Old 01-18-2009, 08:27 AM
Tsvi Tsvi is offline
Turn Signal Problem
I'm having a problem with my drivers side front turn signal - it doesn't work. I've replaced the bulb and still nothing. When I turn on the parking lights, the light goes on but thats a different filament. I think its a wiring issue, but I don't know where exactly. Everything looks ok by the headlight assembly (ie no burnt wires, everything seems connected).
Any ideas?
Old 01-18-2009, 02:45 PM
willieray3 willieray3 is offline
Re: Turn Signal Problem
I had the same problem with mine, I used wd40 in the socket cleaned it with a Q tip and it started working fine. Might have been just luck, it didn't look to dirty but the Q tip was, I think I used a couple of them.
Old 01-21-2009, 08:36 AM
No, still doesn't work. thanx though!
Old 01-21-2009, 08:48 AM
dtownfb dtownfb is offline
Sounds like the bulb connector is bad. Very, very easy to replace (also a very common repair). You can get the part at dealership or online (www.rockauto.com, www.gmpartsdirect.com).
I think GM has successfully proven that the use of the turn signals as the DRL are not a good idea. For sun on your next long trip, count how many GM vehicles you count that have one turn signal out.
Old 01-21-2009, 09:57 AM
Jimmy Olsen Jimmy Olsen is offline
After you repair the bulb connector, pull the fuse on the DRL. If you want DRL, turn on your headlights.
On my intrigue, after I pulled the DRL fuse, I placed bright aluminium strips (about 2 inches wide) around the front bumper area.
1995 Dodge Ram 1500, 143k miles
1999 Oldsmobile Intrigue, 121k miles
2006 Subaru Forester, 68k miles
Old 01-21-2009, 12:23 PM
yeah i've noticed it around.
whats the name or the product number of the bulb connector? is it the DRL resistor connector (DORMAN Part # 84757)?
thanx
