Go Back   Automotive Forums Car Chat > Dodge > SRT4
Old 01-17-2009, 08:50 PM
0550trimsrt4 0550trimsrt4 is offline
i have another question
i have this fludder noise that happens when i let of or shift i thought being a newb to turbocars that was my blow off valve but i was told it was not it is a slow fludder i was told it was turbo blowback were it is air going back torward the turbo after it has already been throgh i was told it is bad if so how do i get rid of it
Old 01-17-2009, 11:57 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: i have another question
That is called compressor surge. It is extremely detrimental to the turbo and will ultimately cause premature turbo failure. Just to give you and idea of what's going on...the air that normally would be release out of the intercooler pipes by the bov is now no longer able to escape so it backtracks back through the system and causes the blades in the turbo to try and spin the opposite direction. Make more sense now? What type of bov do you have? It needs to be readjusted, whether it uses washers or an adj. screw, something needs to be fixed, quick.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 01-18-2009, 09:15 AM
i have a greedy bov i dont believe i have ever heard it go off i just get the fludder i was telling you about thank for all the info
Old 01-18-2009, 01:14 PM
Turbodog97's Avatar
Just a Neon
Okay since it is a Greedy, there should be an adjustment screw on the top of it. Also, where is your vacuum line connected to? It should be t-ed off of the throttle body and go down to the little nipple on the top(or side) of the bov.
05 Srt4
97 Mx-5
Old 01-18-2009, 08:28 PM
i adjusted the screw and it made no difference turn one way for soft and the other way for hard tried both no difference i keep the car in a garage and im away from it for the night but i will check it tommorow for a tee and a vaccum line
Old 01-24-2009, 02:10 PM
i got it where it blows off with low boost around 8 pounds so i dont hear the fludder anymore yea but for the widband i have a plug in the hole were the o2 wideband goes that the previous owner put in when i assume he took his out before he sold it but the plug was rusted so bad i had to have a another one put on but it should be good to go now
Old 06-09-2009, 09:49 AM
srt4killsu srt4killsu is offline
That kind of surge isnt that bad.. All turbos have it, most BOV cant get all the air out so some will go back throw, but the surging at full thottle and low rpms is bad and can cause damage. Also what line are you using for a vaccum sorce?
05 Srt4. Mods: ACT 6 Puck Clutch, Wisco pistons 8.8-1, Eagle rods, BC cams and valves, adj. cam gears, Race ported head, Ported intake mani, 55mm TB, 3" TBE, 255l pump 1100cc inj and Diablo sport. Oh yeah and Twin Turbos 603hp on meth inj. and pump 92
