Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-17-2009, 07:46 PM
JustBoost JustBoost is offline
1990 TSI Talon
Hello im Really Stuck i have a 90 Talon TSI and i dont know whats wrong with it i took it to a Mechanic and he told me to change the ecu, coil, and fuel pump. ok so i go out and buy new ones put them in and the car still wont start. ok thats the story
this is what happens when i put the key in and turn it.
the boost gadage does not turn on the car wont turn on......
BUT when the boost gadage does turn on the car will TURN ON WOOT..
but sad cause the problem
thx
Old 01-18-2009, 07:08 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 1990 TSI Talon
Pretty hard to diagnose a problem like that with just that info. Is there any back story to when this problem began happening? Is it all the time or just sometimes? What differences do you notice when it does or does not start? Cold weather, warm weather, etc. When it does run, does it run normal or does it stutter and blow smoke? The more details you provide, the better we can help try to diagnose the problem. Personally, I would not have started with the ECU, fuel pump and coil pack. All are very expensive items to replace and usually less common problems than simple things like a bad MAF sensor or a bad ignition module.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-18-2009, 09:09 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: 1990 TSI Talon
The boost gauge is controlled by the ECU. If it doesn't go to zero with the key in the start position then that would point to the ECU. The Check engine light will also come on for a short period of time with the key in the ON position.
I had the same thing happen to me a couple years back and a new ECU fixed it. Sometimes the gauge would go to '0' and when it did the car would run for a few seconds. If you replaced it, maybe you have a broken wire somewhere that makes an intermittent connection.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 01-18-2009, 09:10 AM
Testiklees
Re: 1990 TSI Talon
Also, make sure you replace the ECU with another 1990 model. The other years are interchangeable, 90 is not.
Tim
1990 Talon AWD
PTE SCM5031
