Old 01-17-2009, 05:24 PM
charlie40 charlie40 is offline
1991 7.4 no spark no fuel
i changed everything but the ecm still no fuel or spark. the only thing i didnt check or replace was the pickup coil in the dist. would this cause no spark or fuel.thanks.
Old 01-17-2009, 05:37 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1991 7.4 no spark no fuel
Yes it could.
How is the voltage to everything?
Have you check the dist module?
Is the dist turning when cranking?
MT
Old 01-17-2009, 07:24 PM
the voltage is good on everything in the ign and fuel sys. i changed the coil,ign module,oil pressure switch,pump relay,checked all fuses,but i dont have power to pump fuse under the hood. i didnt check the pickup coil in the distributor,or ecm.thanks
Old 01-17-2009, 07:32 PM
MT-2500's Avatar
AF - Advisor
You are welcome.
Pickup coil would be next on the list.
Let us know how it goes.
MT
Old 01-17-2009, 09:18 PM
im going to check it in the morning ill let you know what i find out.thanks again
Old 01-18-2009, 06:50 PM
it was the pick up coil in the dist. thanks for all the help. you guys always come to the rescue.
Old 01-18-2009, 07:17 PM
MT-2500's Avatar
AF - Advisor
You are welcome.
Glad you found it.
And thanks for posting back with fix and how it went.
MT
