Old 01-17-2009, 09:38 AM
RANDY1957 RANDY1957 is offline
clutch bleeding
have a 1997 chevy s-10 2.2
how do you bleed the clutch
Old 01-17-2009, 10:18 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: clutch bleeding
Why does it need to be bleed?
Clutch replace or master cylinder or line replacement or dry on fluid?
To bleed fill master cylinder and open bleeder valve.
And pressure on clutch pedal?
You can pump some air out like bleeding brakes.
But for final bleed I fill master cylinder and leave cap off and open bleeder valve without pumping pedal let it gravity bleed.
MT
Old 01-17-2009, 10:23 AM
Re: clutch bleeding
it ran low on fluid--but do you know where the bleeder valve is, can't seem to see it??
thanks
Old 01-17-2009, 11:16 AM
MT-2500's Avatar
AF - Advisor
Re: clutch bleeding
thanks
If the pressure lines runs into the clutch area the bleeder valve will be right next to it where it goes into transmission housing.
MT
Old 01-17-2009, 05:53 PM
Re: clutch bleeding
thank you
Old 01-17-2009, 06:49 PM
MT-2500's Avatar
AF - Advisor
Re: clutch bleeding
You are welcome .
Let us know how it goes.
MT
