Old 03-22-2003, 10:32 PM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
radiator
OK i was wondering if a 90-93 teg radiaotor will fit in out cars since a 92+ civic will except a 94+teg rad then why wont are cars take a 90-93 teg rad ??? i was looking at one today it seemed MUCH thicker and better built than our little dinky ones and i thought that that might be a nice upgrade instead of buying a FLYIDYNE
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
Old 03-23-2003, 04:49 AM
91civicDXdude's Avatar
OK i was wondering if a 90-93 teg radiaotor will fit in out cars since a 92+ civic will except ....
have you seen a 92+ radiator? those things are dinky compared to ours. Our radiators stretch the entire width of the car whereas the 92+ is a small dinky thing. I would think that an integra radiator would bolt in with no problems, but you have to think that if its a thicker radiator, you might have problems with your cooling fan hitting on an aftermarket header. I know my DC sports sits pretty close to the fan as it is.
Old 03-23-2003, 06:38 AM
i thought the 90-93 teg radiators were BIG they spanned the whole support?? i think ur thinking of the 92+ civics radiator
Old 03-23-2003, 06:43 AM
thats what i said. the 92+ civic has a small radiator and the teg has a full sized radiator
Old 03-23-2003, 07:12 AM
yes i relize that buy my question was... will a 90-93 teg rad fit in our 88-91 civics?? becuase they are built on the same platform... MY logic to this swap was that if a 94+ teg rad will fit in a 92+ civic then why wont the 90-93 teg rad fit in a 88-91 civic??
Old 03-23-2003, 08:25 AM
try it and see. obviously it will fit as the front end of a teg will fit on our car, its the same width. You might have problems as far as mounting goes, as even in 92+ civics you have to "remount" the teg rediator for it to fit.
Cracked Radiator, what other ar radiator can fit? J_J_T Grand Prix 3 03-04-2006 10:03 PM
How much antifreeze could a radiator hold if a radiator could hold antifreexe? emperor_of_weasels Beetle - New/New Beetle Convertible 1 07-24-2005 12:34 PM
Radiator - Discount Radiators from $89 ! lilipkk Tires and Wheels 0 01-26-2005 05:26 AM
Radiator hose bulging and coolant coming out of drain on bottom of radiator? 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 01-18-2004 06:14 PM
