Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-16-2009, 03:03 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
radiator hoses...
does anyone know where i might be able to find a set or performance radiator hoses for my rs? i only keep finding kits for turbo eclipses...or would the hoses be the same for the turbo eclipses as they would be for my rs?? btw i have a c&r radiator...
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 01-16-2009, 09:38 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: radiator hoses...
I dont' know where the inlet/outlets on a C&R radiator are but you can find 'performance hoses' on eBay. OBX makes some good silicone ones. Check on CI Motorsports also.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-16-2009, 10:00 AM
okie doke, will do. thanks!
and fyi by "performance" i meant, able to withstand high temps
Old 01-16-2009, 10:12 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Just run the stock replacement hoses from advance. Thats what I run and never have any problems. If your exhaust is so close to the hose that it is exposed to extreme heat then it should be protected. Trying to swap to a hose that MAY be able to withstand higher temps is not a good solution.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-16-2009, 01:25 PM
not really TOO close, its more of a thing of me trying to improve the overall cooling efficiency, not so much that the hose is in a bad spot...
but thanks, i found the perfect kit on ebay...=) $45 for upper and lower black obx hoses....
not bad?
Old 01-16-2009, 01:53 PM
david-b's Avatar
Dave is THAT guy
not bad?
That's the going price for those OBX hoses pretty much anywhere. I honestly don't think that there's a different with cooling by using those hoses. It's more to stop the stock rubber ones from melting. What would be nice would be to see a log of a before and after (same exact conditions) but with the different hoses. I'm sure there's no change.
75 Monte Carlo
Old 01-19-2009, 06:21 PM
Holset powered 420a
My stock hose last over 2 years within 1 inch of the DP so the stock hoses are more than good.
98 Eclipse GS Turbo
2001 BMW 325i - DD
