Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-16-2009, 01:33 AM
Eclipser80 Eclipser80 is offline
Send a message via AIM to Eclipser80
Question Leaking HG
So the high idle problem was fixed..low on coolant so it messed with the sensors. But my new question is say the fluid was half a gallon(no kidding) low because of a leak. I hear if it were to leak itd be from a head gasket. how hard is it to repair? And if I'm wrong on something please correct me I'm still learnin
1995 Mitsubishi Eclipse GS Non-turbo
Old 01-16-2009, 09:41 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Leaking HG
Not sure exactly what you're saying in the 1st half of your post. Missing coolant doesn't necessarily mean it's the headgasket.
But for a headgasket, you have to pull the timing belt off and everything that goes with that and then pull the head off. Not a super easy job, but not too bad.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-16-2009, 10:10 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Leaking HG
Just because your leaking coolant doesn't mean its the headgasket. There are TONS of places that coolant could be leaking from. Check your hoses, water pump, leaks around the thermostat housing, etc... The headgasket should be the last place you look for coolant leaks.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-16-2009, 10:15 AM
david-b's Avatar
Dave is THAT guy
Re: Leaking HG
I forgot to add... check your oil for coolant. Drain it and see if any coolant is in there. That will usually result in a bad headgasket, but as stated above check everything else first.
75 Monte Carlo
Old 01-16-2009, 12:58 PM
Re: Leaking HG
Okay i was just asking like if it was how hard is it i hope its not leaking anywhere and the prev owners just never put any in.
Old 01-16-2009, 02:36 PM
steviek's Avatar
steviek steviek is offline
Re: Leaking HG
you really don't want it to be the head gasket.
hopefully its something else (or nothing)
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
