Old 01-15-2009, 10:33 PM
gregary moyer gregary moyer is offline
lights going crazy, could use some help
I think I narowed it down The lights and gages go crazy when I step on the gas but only when there is a load on the motor could it be the alernater(it charges the battery just fine)
Old 01-16-2009, 01:24 PM
readallen readallen is offline
Re: lights going crazy, could use some help
loose or corroded ground(s) and/or wire(s). even if battery and grounding connections look ok, still clean really good
Old 01-17-2009, 08:25 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
When random crazy shit starts happening: Check all possible grounds.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 01-17-2009, 10:00 AM
HondaDriver1990 HondaDriver1990 is offline
Check your grounds then you might need to get a new voltage regulator, same thing happend to me but i never had good enough grounds for the load so it kept burning out the regulator and the problem would happen over and over again.
Old 01-19-2009, 06:14 PM
Thumbs up Re: lights going crazy, could use some help
I took the groud from battery to frame sanded down the contac and the frame No more crazy lights and tack. thanks guys
