Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-15-2009, 11:30 PM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
intake mani and TB?
so, i just spent a good hour reading people argue about whether or not its a good thing or a bad thing to add an intake mani and a TB to your 420a...
so i wanted to ask all of you trusty dsm'rs your opinions...
with my mods...what would i realistically see in gains(or losses) across the board with an aftermarket intake manifold and throttle body?? also taking into account whether or not the benefits match the hassle..
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 01-16-2009, 09:43 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: intake mani and TB?
The stock IM flows fine. You may just want to port and smooth out the runners. A lot of people buy those OBX IMs but I think they're more for show. Never seen anything saying those made anymore power.
As for the TB, get that bored to 55mm or 57mm. That should be fine.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-16-2009, 09:56 AM
does it make any difference if its bored or if i buy one aftermarket thats already that size?
dunno if there is anywhere around here to do much machine work where i live...=(
at least not that i know of...
i would just assume buy one and install...any probs with doing that?
Old 01-16-2009, 10:15 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Port and polish your intake manifold. Your also going to need to port out the opening where the TB bolts up. You can buy a bolt on TB and be good to go but they are a little on the expensive side. With your mods I would go to a 60mm TB. You can also buy one of these or do the jeep 60mm TB mod like I did. Total cost was like $25 for the jeep TB. Check 2gnt for a write up on the mod.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-16-2009, 02:34 PM
steviek's Avatar
steviek steviek is offline
I just want everyone that might search this to know this ithread is based on the 420A motor.
The 4g63 especially the 2g's are in a painful need of a freer flowing intake mani and tb in anything of excess of a s16g.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 01-16-2009, 03:55 PM
60mm it is
recommend a good brand?
Old 01-17-2009, 12:55 PM
steviek's Avatar
a throttle body really isn't that complicated a part. Its just a plate that opens and closes with a couple extra holes for some emissions and things. I would say just whatever fits and is cheap. I don't know which ones go on the 420a's no experience.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 01-18-2009, 12:43 PM
david-b's Avatar
Dave is THAT guy
For the most part the 420a's use stock TBs. I honestly can't think of 1 aftermarket TB. Best bet is to get it bored out or go with the Jeep TB as Silver stated. Can pull them off junkyards for cheap.
75 Monte Carlo
Old 01-19-2009, 06:19 PM
Holset powered 420a
The stock TB can not be bored past 57mm. There is one company that makes aftermarket TBs but I cant think of them off the top of my head. Search around some and you will find it. They are pricey though.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-30-2009, 12:37 AM
i founda good throttle body, i think it was 62mm
so any of you ever used/installed an aftermarket intake manifold?
Old 01-30-2009, 12:42 AM
steviek's Avatar
I'm about to do both of them soon as the weather is plus anything
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 01-30-2009, 05:06 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Dont even waste your time with your mod list on an aftermarket intake. Bore the TB sure, but 62mm? Overkill as hell. Aftermarket IM's, particularly the sheet metal ones, are only really power adders in the upper rpms and if memory serves they actually take away a lot of your low and mid range. Great if you're going to be running around the track at 6.5-9k constantly, but for every day use you're going to be basically making your car slower. Regardless, those are for big turbo guys running their stuff to the tits, and even if you were boosting the shit out of that little 16g and tracking it, I'd be suprised to see even a marginal gain.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-30-2009, 07:42 AM
Holset powered 420a
I run a 60mm. A 62mm would be fine, there are not to many people that use aftermarket intakes on the 420a motor. And the ones that do I haven't even seen a dyno sheet showing the gain performance. I think its more of a show mod than anything.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-30-2009, 12:49 PM
steviek's Avatar
I' m about to put on a 62mm tb too
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
