Problems with vct on dual overhead cams
Motor will run when cold and idle when cold after warming up does not idle runs like its to rich any sugestions? wondering if vct could be the problem
Any other suggestions highly requested Car is a 1998 Ford Escort Zx2 2.0 16 valve ztech we have adjusted timing to top dead center aligned all timing marks still seems like it is out of time No Codes being thrown Last edited by ketinc; 01-15-2009 at 09:52 PM. |
Re: Problems with vct on dual overhead cams
you need put year and motor size and little more enfo.
Yet again, as I often do, I suspect a vacuum leak. When the engine is cold the mixture allows the engine to keep running, but as the temperature changes the mixture does as well, and you may be getting too much air which is causing it to die.
