Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 01-15-2009, 07:15 PM   #1
jaynlisa
Smile no heat on the seat. its cold outside
I have a 1999 Oldsmobile Bravada. I love mine, just a few gliches. I to am a female. My problem is... The heated seat on drivers side doesn't work. The electric seat itself moves and lumbar works just no heat on the seat. Any helpful pointers would be helpful. Is there a fuse that controls that, or a wiring problem. Oh, the heated seat on passenger side does work. If that makes a diffrence. P.S. I didn't get a owners manual with the this. I know it doesn't help matters. Any help would be greatly appreciated
jaynlisa is offline   Reply With Quote
Old 01-16-2009, 09:40 AM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: no heat on the seat. its cold outside
You might look under the seat and see if anything is unplugged.
Chris Stewart is offline   Reply With Quote
Old 01-19-2009, 11:30 PM   #3
ericn1300
AF Premium User
ericn1300's Avatar
Power seat problems should be taken very seriously as Bravadas of your vintage have been known to burn down in the middle of the night with out the key in or anybody about. There are two problems with the seat wiring, 1. the wiring harness runs under the carpet on the drivers side near the gas pedal and 2. the wiring harness also is subject to wear as it runs past the metal brace in the seat.
http://www.automotiveforums.com/vbul...highlight=fire
ericn1300 is offline   Reply With Quote
Old 03-11-2009, 12:48 PM   #4
chevman57
More than likely the seat heater itself is burned out and needs to be replaced. The seat has to be pulled and the seat cover removed to do this.
Terry
chevman57 is offline   Reply With Quote
