Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-15-2009, 05:26 PM
90sabre 90sabre is offline
99 Ram still no heat
So after replacing the water pump, t stat(3 times) and fan clutch I was able to somewhat solve the problem of no heat. I do get a little heat on the low fan speeds but it gets cooler if I go to the third or fourth positions. This is ok when it's 30 or 40 outside but on days like today when the high was 4 degrees it's almost like having no heat at all. I know the heater core isn't blocked(both hoses are hot). The coolant is clean and full, I really don't think the heater core is leaking. The only things I can even think to check are maybe the actual vents or other parts under the dash. Not sure where to begin here, or if there is anything anyone can suggest but I need heat, at least more than this. I've tried running it on the max ac setting rather than defrost but it only made a small improvement. Any help is appreciated, I'm getting desperate.
Thanks!
Leo
99 S10 LS 4.3L 2WD
07 Chevy Trailblazer 4X4
Old 01-16-2009, 01:53 AM
mxz600 mxz600 is offline
Re: 99 Ram still no heat
On my 95, the blend door under the dash had the cable attaching point
broken/unhooked. Shop rolled the dash back and jury rigged a repair to it
and it's been working fine every since.
Jay
Old 01-16-2009, 04:21 PM
angus10 angus10 is offline
Are both hoses going into the firewall where they connect to the heater core hot?
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
Old 01-16-2009, 08:02 PM
They are hot enough that I can only grab them for a few seconds. They seem hot enough to me, but I've also heard that you shouldnt even be able to touch them...
Thanks!
Leo
99 S10 LS 4.3L 2WD
Old 01-16-2009, 08:16 PM
tmenna tmenna is offline
I am having the same problem in my 98 Dodge Ram and have done EVERYTHING to repair the problem. I was informed to cover the radiator with card board and that is supposed to help. Have you tried that? I am going to try that tomorrow.
Thanks!
Old 01-16-2009, 10:07 PM
It helped me when I couldnt get the engine up to temp but is really just a temporary fix and you have to be careful not to let it overheat, not a great option in my opinion but it might get you the results you want.
Leo
99 S10 LS 4.3L 2WD
Old 01-17-2009, 06:00 AM
I have basically the same prob, a couple weeks ago I flushed the core and it is a lot better. Sometimes even if the hoses are hot the core is still partially plugged. Flushing gets rid of the loose debris but not the white lime deposits.
And you can check the blend door by rapidly rotating to full hot and full cold, you should hear it slam where it seals.
I know it's my core and will be replacing it come spring.
98 Ram 1500 4x4
Old 01-17-2009, 07:59 AM
Mopar guy Mopar guy is offline
Hello. Disconnect your hoses from the heater core. Hook up a spare piece of garden hose and try to blow thru it with your mouth. There should be no restriction. You must flush out the core with a garden hose from both directions several times. I usually use a hose clamp because if the core is really plugged it will blow the garden hose off. I also take a rag around the core openings after and blow air thru both directions. When it is clean you can blow thru it as easily as exhaling. I had one in a '80 bronco that only had a trickle of fluid dripping when I unhooked it because it was so clogged. That one took alot of cleaning out.
Old 01-17-2009, 11:44 AM
Thanks everyone...
It's supposed to warm up to above zero tomorrow, so hopefully I can give this a try. I will keep you posted.
Leo
99 S10 LS 4.3L 2WD
Old 01-17-2009, 11:51 AM
Thanks everyone...
Also, is there type of additive or anything you can buy that will free up any clogs in the core?
Leo
99 S10 LS 4.3L 2WD
Old 01-17-2009, 01:14 PM
hundahunta hundahunta is offline
you might be able to remove the heater hoses and try to flush it with the water hose and check flow
Old 01-17-2009, 03:24 PM
You can use brake parts cleaner. Just spray it into the core before you flush with water. Use about half a can and let it sit 5 minutes. Usually not needed though. You can also use to final clean out after you flush with water. Be sure to blow any brake cleaner out of care until your sure its dry inside. You don't want any left in there, it wont be kind to rubber hoses or seals.
Old 01-18-2009, 05:31 AM
You can also use CLR, after you remove the hoses blow out as much coolant as you can by mouth. Keep both hoses up high (I used some wire and hooked them to the hood) and pour some CLR into one of them, then some water untill both hoses are full. Let it stand 10 or 15 minutes (let the hoses back down)then flush. And btw, the first flush should be a back flush, in other words , the opposite direction of normal flow. Which would be the hose on the driver side first.
98 Ram 1500 4x4
Old 01-19-2009, 05:04 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Just the clear water flush has worked for me when I had a clogged heater core.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 01-30-2009, 06:51 AM
So, I haven't had a chance to do the flush due to the weather. I did check the heater hoses again and both are hot, the passenger side is too hot to grab and the driver side is pretty close to that temp. Should they be the same temp?
Also wondering what to look for to check the blend door. I looked under the dash at the blower motor area, but I'm not sure where to find the blend door or even what to look for once I find it. There is a silver canister about 3 inches tall with a vacuum line coming out of it, is this some kind of control?
Thanks again!
Leo
99 S10 LS 4.3L 2WD
