Old 01-15-2009, 09:05 AM
marine4lifedoc marine4lifedoc is offline
Angry error code is P0141 Bank1 Sensor2. came back on
I went and got a emissions test and I failed becasue the check engine light came on and the error code read P0141 Bank1 Sensor2. So I went to the auto store and bought a a downstream O2 Sensor and had a mechanic install it and turn the light off and a hour later it came back on can anyone please help!
Old 01-15-2009, 02:33 PM
kwk39018's Avatar
kwk39018 kwk39018 is offline
Re: error code is P0141 Bank1 Sensor2. came back on
did the code get erased after he installed the part?
It might a pos, but its my pos.
Old 01-15-2009, 04:26 PM
Angry Re: error code is P0141 Bank1 Sensor2. came back on
The mechanic used the computer to erase the check engine light and afyter about a hour of running it came back on
Old 01-15-2009, 04:37 PM
old_master's Avatar
Advisor/Moderator
P0141 indicates a problem with the heater circuit, it does not say replace the sensor. Diagnostics for P0141 include checking the fuse, and the wiring to the sensor. Ignition in RUN position, heater wire must show battery voltage. The ground wire must show less than 5 ohms resistance to ground. Post your results and we can continue if necessary.
Old 01-16-2009, 08:20 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with old master that the circuit needs to be checked. Another possibility is the new sensor has a bad heater circuit (especially if you bought a Bosch branded sensor, they are infamous for heater circuit issues).
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-24-2009, 05:26 PM
Is there anyway I could this myself and if not about how much would it cost to fix the prolem if it is what u said
Old 01-24-2009, 07:58 PM
discnik discnik is offline
Maybe I missed it, but what year, make, model, engine, please ?
Old 01-24-2009, 08:15 PM
05 cavalier 2.2 4 cyl
Old 01-24-2009, 08:31 PM
You can check for battery voltage at the heater(O2 sensor), brown-pink wire.
If good then check ground wire, black wire.
As far as cost of having a shop do it ? Depends on how long it takes to find the problem and how fair minded the shop is.
