Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-15-2009, 08:42 AM
HV2JEEP HV2JEEP is offline
stuck in 4wd
A friend of mine is having a problem with his 02/03 Ram 1500. he left his house this morning and switched it out of 4wd. a ways down the road he started to hear a grinding noise like it wasn’t all the way out of 4wd. he switched the 4wd back on and the noise went away. It is very cold here this morning like zero. Could it be something is frozen? Is the independent front end vacuum or electrically actuated? Im not familiar with the independent front end. we have it in a heated garage right now to see if its something frozen. How can we remedy this?
2000 Jeep Grand Cherokee limited 4.7 V8
2001 Dodge Ram 2500 8.0 v10
K&N, true duel exhaust, 9’ Boss plow
1997 jeep wrangler TJ sport 4.0 I6
4” Super Lift, Waren bumpers, 33” BFG MT
1996 Volkswagen Passat GLX V6 (just got it)
Nothing yet, but mods coming soon.
Old 01-15-2009, 11:15 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: stuck in 4wd
To disengage the 4wd ideally you should be on a slick surface...a little slack is needed. Have your friend find a gravel road or snowy/icy stretch. If it won't disengage while driving straight, then try a slight turn either left or right.
What happens is that the system binds, and because of the pressure put on it will not disengage. The slippery surface and/or turning will help relieve the pressure. (Pressure is similar to when you are in 4wd and turn on pavement: not recommended)
Hopefully by now it's come out; this system is NOT to be driven in 4wd on pavement so your friend may damage his 4wd system if he does.
Hope that helps....
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-15-2009, 11:47 AM
Re: stuck in 4wd
He knows how to use his 4wd. he called a mechanic that’s knows dodges and he had him check a few things over the phone. He thinks its something to do with having a bad axel shaft. he said that the shaft is pulling out of the housing because of the torsion bar leveling kit that the truck has. So maybe it was a front axel thing and not a 4wd thing. I haven’t seen it myself but this mechanic knows his stuff. He is going to check it out today. hopefully he wont break the bank. Damn independent suspension.
Old 01-15-2009, 12:56 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: stuck in 4wd
Well, for once, a vehicle owner is well-equipped to solve their own problems.
I wouldn't condemn an IFS 4wd set-up. At times, I wish I had bought one instead of my solid-axle Jeep.
FWIW, I found alternating going forward and reversing is a great way to disengage a sticking 4wd mechanism.
