Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Brakes and Suspension
Old 01-15-2009, 01:29 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
brake lines install
hey guys, i had a few questions before undergoing an install on some brake lines...ive done plenty of brake work, just never removed brake lines to install "performance" ones...
is there anything special i should know?? such as when doing the install, or maybe when selecting the parts company to go with?
can anyone with experience tell me right off hand which size lines ill need or what to look for in a kit for my 97 rs?
and finally, with my ultimate hp goal being about 450, are performance brake lines even necessary? what major benefits if any will they realistically produce??
thanks!!
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 01-15-2009, 08:00 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: brake lines install
You do not have to have them. I would upgrade the calipers to GSX calipers and rotors before I the line. All they will give you is a more solid pedal feel. I have never used them so I dont know if they help or not. I have a write up in the tech section for upgrading the brakes.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-15-2009, 10:30 PM
Smile Re: brake lines install
so in other words, its up to preference whther or not to do it...
lol, thanks thats all i needed to know
Old 01-16-2009, 10:23 AM
Holset powered 420a
Yes its up to you whether you want to spend the money on them. Like I said you should upgrade to the GSX calipers also. Being able to stop the car is MORE important than making it go faster. You should atleast replace the lines with some new ones as your stock lines are over 10years old now. If you choose to go with the gsx caliper upgrade be careful that you get the right lines for the front. Some of the 2 piston calipers came with banjo fittings like your stock ones and others came with screw in fittings.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-16-2009, 11:38 PM
thanks for the heads up, i would have gotten there and realized it and been pissed lol...knowing my luck
Old 01-23-2009, 03:51 PM
well, while we are on the subject...i have a few questions about the brakes
1)you recommend gsx calipers, does this mean i can just buy new calipers that are made for a gsx and put em on mine, or do i need to actually find a parted out gsx and pull them off bc that might be kinda hard to do
2)will the gsx calipers fit right on or will they require mods, and what pads do i get? ones for the gsx calipers or the ones made for my car? in other words will i have problems with fitment and whatnot
3)how easy/hard is it to convert my rear drums to calipers on the eclipse...if you or anyone has done this...
thanks!!opcorn:
Old 01-23-2009, 04:05 PM
Holset powered 420a
http://www.automotiveforums.com/vbul...d.php?t=739075
Never done a drum to disc brake conversion so you will have to search that.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-25-2009, 12:36 AM
i just realized, i have aftermarket rotors, id have to trash em to do the upgrade...=(
but the lines i will do, you put it perfectly yourself, mine ARE about 10 years old now lol
Old 01-25-2009, 10:23 AM
Holset powered 420a
Thats why you just upgrade when you need to change your brakes. You would have to buy new ones anyways.
98 Eclipse GS Turbo
2001 BMW 325i - DD
