Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 01-14-2009, 08:45 PM
dssdj2007 dssdj2007 is offline
chevy g30 heating problem
Hey guys i have a 88 chevy g30 with a 5.7 L and turbo 300 trans. I am having heating issues with my van. When i am parked it blows warm air just fine and actually pretty warm air. When i start driving it starts to blow cold air does anyone else have a problem like that and is it an easy fix.
Old 01-15-2009, 07:57 AM
maxwedge maxwedge is offline
A990 racer
Re: chevy g30 heating problem
Lets get you to the right forum, G-Van below.
Old 01-15-2009, 09:35 AM
A990 racer
First check the coolant temp at running speeds, feel both heater hoses, may have to use a non contact thermometer to do this properly. Possible bad t'stat ,where does the temp gage sit, these are all basic steps to figure this out.
Old 01-15-2009, 10:37 AM
well the hoses are hot and the heat blows warm air when its sitting in park but when you start driving it goes cold i put cardboard in front of the radiator and that didnt help i did not change the thermostat yet
Old 01-15-2009, 01:37 PM
A990 racer
Does the gage go up to the normal range and again what is the actual temp of the coolant, until you have that info you cannot really tell what is wrong.
Old 01-15-2009, 03:30 PM
how do i go about checking the coolant temperature
Old 01-15-2009, 06:31 PM
A990 racer
By the gage, is it lower than usual or a thermometer in the radiator. Or as I suggested above, an infrared thermometer.
Old 01-16-2009, 11:46 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
More than likely the heater control valve is sticking. If the hoses up to it are hot, its probably bad.
Bob
