Old 01-14-2009, 04:50 PM
duh1 duh1 is offline
tdc after eplacing head gaskets 4.3
i marked my distributor placement, but didn't mark my rotor placement.
if i turn the crank pully to the point where both #1 valve pushrods are at their lowest level, i am at tdc for number 1 cylender, correct? one of the crankshaft pully notches is highligted, but i think it's the wrong one, it was marked on a previous repair.all i'm getting using that one is backfire indicating bad timing, any suggestions? sorry, first post, it's a 94 4.3, and i'm tearing my hair out, thanks
Old 01-14-2009, 07:56 PM
tempfixit tempfixit is offline
Re: tdc after eplacing head gaskets 4.3
Check this thread out, it's from the Blazer forum in the How To/Technical Info:
http://www.automotiveforums.com/vbul...d.php?t=881442
Hope it helps
Old 01-14-2009, 08:46 PM
bracketshark bracketshark is offline
Rotate the motor in normal direction watching #1 cylinder intake valve open then close keep going until the dampner mark aligns to the 0 on the timing tab. The motor is now at TDC for #1 cylinder assuming the dampener hasn't slipped. You can rotate it with the starter but be careful. Hope That helps.
Old 01-14-2009, 09:28 PM
yes, thanks guys, that does help, since there are 2 marks, and i foolishly didn't highlight the mark before tear down, this may help. i'll let u know tommorow, thanks again
Old 01-15-2009, 09:13 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Forget the timing marks for setting dist.
Two ways to find TDC no 1 compression stroke.
Bring it up to comptression stroke by finger feel for compression.
Then take a brass welding wire and feel for tdc on piston.
Or when the valves are rocking {one closing and one opening} on your opsite firing cylinder no 4 cylinder.
You are at tdc compression stroke on no 1 cylinder.
Then see what timing mark lines up TDC and use that one to set timing after the engine is running.
Good Luck
MT
Old 01-15-2009, 04:00 PM
well, no luck so far. when i adjusted the valves there was no compression. should i turn the engine over for a few seconds to pump up the lifters, or should i just back off each rocker arm nut 1/3 turn on all till it fires up, or what. i am completely confused now. however, i feel i have established tdc on the compression stroke of #1, it lines up with a mark on the balencer, and both #1 pushrods are at their lowest levl equally.
Old 01-15-2009, 05:02 PM
MT-2500's Avatar
AF - Advisor
You need to check the opsite firing cylinder for the valve rock to get the true top TDC compression stroke.
When valves are all of the way closed on a cylinder .
Back off rocker arms on that cylinder untill you can spin push rods by hand.
MT
Old 01-16-2009, 12:27 PM
i'm fairly confident i have tdc now, but before adjusting the valve lash, should i 'spin' the engine on the starer to 'prime' the lifters or what. or, should this be a new thread?
Old 01-16-2009, 01:13 PM
MT-2500's Avatar
AF - Advisor
This thread is good.
You should be able to feel the top of lifter without priming it up.
A good lifter will be spring loaded from borttom to top.
Are you going to adjust valves engine running or before you start it?
MT
Old 01-16-2009, 02:10 PM
well, finally got it started, thanks to everyone, especially mt 2500, now to fine tuning, couldn't have done it w/out u guys. i will post back in a few hours, wish me luck. thanks again
Old 01-16-2009, 02:35 PM
MT-2500's Avatar
AF - Advisor
You are welcome.
Let us know how it goes.
MT
Old 01-16-2009, 10:15 PM
well boys, big trouble, water in every cylender. i'm gonna take a compression test tomorrow, an hope i just screwed up the intake gasket. don't know how a cracked block would let water in every cylender. oh, well, i'll see tomorrow but, i did get it cranked.
Old 01-16-2009, 10:27 PM
What was the actual reason for replacing head gaskets? WOuld you explain the problem before you started.
Old 01-16-2009, 11:05 PM
sure, it was overheating. and it was time for a valve job. but it has been a bitch to get it back right. i'm hoping all i did was hoop the intake manifold gasget this time
Old 01-16-2009, 11:55 PM
Don't take this wrongly by me asking these questions just attempting to help.
What did you find for problem causing overheating? Were the head gaskets or intake gasket bad?
Did you have the heads magnafluxed for any cracks and checked the heads for any warpage? What brand gaskets did you use?
How many miles on engine? What year vehicle.
If you would give us any detail that you think could help diagnosing that would be great. Like you stated hard to believe that coolant in every clyinder.
