Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-14-2009, 01:00 PM
gbelous gbelous is offline
Question Start Problem and Code Question...
First, what do these codes mean I need to do?
25 - Inlet air temp. (IAT) out of range high
26 - TCC stuck on
Second, Can anyone think of a reason why after sitting for a weekend, the car starts, but when I put it into drive and press the gas it bucks and dies? I got it running by adding gas (even thou it was at least at 1/4 tank or more) and by adding dry gas. I was thinking water in the lines, but could it be a clogged fuel filter? Once it's running it stays running and drives fine....however the other day I noticed it idling rough when I was sitting in traffic...almost to stall but it never did.
Since this site is really slow I was able to do some research on the TCC and it's the torque clutch converter. And if it's stuck....what does that mean and is it something I can fix without ripping the whole transmission apart?
Definitely has me nervous. Any help would be great. Thanks!
