Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-14-2009, 11:38 AM
gbelous gbelous is offline
Question Start Problem and Code Question...
First, what do these codes mean I need to do?
25 - Inlet air temp. (IAT) out of range high
26 - TCC stuck on
Second, Can anyone think of a reason why after sitting for a weekend, the car starts, but when I put it into drive and press the gas it bucks and dies? I got it running by adding gas (even thou it was at least at 1/4 tank or more) and by adding dry gas. I was thinking water in the lines, but could it be a clogged fuel filter? Once it's running it stays running and drives fine....however the other day I noticed it idling rough when I was sitting in traffic...almost to stall but it never did.
Definitely has me nervous. Any help would be great. Thanks!
Old 01-14-2009, 04:05 PM
RC1488 RC1488 is offline
Re: Start Problem and Code Question...
Replace your ECTS. This effects idle controls and transmission items.
CHeck your IAT connection. Could be the wire is damaged going to the connector.
Make sure youve been changing the fluid and filter every 20K. If not..start ASAP
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 01-15-2009, 11:45 AM
I do change the fluids regularly...at least at decent intervals considering the car isnt driven very much each year. I'll look into the ects and the iat wires. Any advice for the way it's running transmission-wise?
Old 01-15-2009, 12:27 PM
Would the IAT be the same thing as the "Standard Motor Products Air Charge Temperature Sensor" from advance auto?
http://www.partsamerica.com/ProductD...pe=756&PTSet=A
Old 01-15-2009, 09:38 PM
Thats the part, but its alot cheaper at autozone.
The ECTS controls many subsystems of the car including tranny operations from shift points, to torque converter lock up points. It rarely has its own code, and usually sets of other SES codes because of it. 10 bucks at autozone, to possibly fix your problem is well worth it
Old 01-16-2009, 12:10 PM
Okay, I'll stop and get it this weekend. I haven't worked much on the Saturn...were would I even find the ECTS?
Old 01-16-2009, 01:30 PM
is the AIT the same as the ECTS? Will replacing the ECTS fix the AIT code?
should i replace both if they are different?
Old 01-16-2009, 04:05 PM
The sensor is the same, but its location and funtion is different. So no a new ECTS will not fic the IAT code, but might fix the tranny code
Old 01-27-2009, 02:03 PM
Yeah...not too sure it's just the sensor throwing off the code...I went to start it last night after it sat for the weekend and reverse wouldn't work. After shifting around and stalling it a few times reverse bucked and grinded and eventually worked. Drove it today to work and it was back to "normal" Drove rough like usual, but didn't stall.
Old 01-27-2009, 02:37 PM
Did you replace the ECTS?
Old 01-27-2009, 02:39 PM
no not yet. but would that cause the transmission not to go into reverse?
Old 01-27-2009, 03:12 PM
The ECTS is used for many subsystems of the car including tranny operations. It is the first part that must be replaced before any other diagnosis is done. Especially since its a 10 dollar part, and 10 min procedure.
Once this is replaced, then move on from there, as some certain symptoms may change.
