Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 01-13-2009, 08:46 PM
lilslim_0401 lilslim_0401 is offline
Unhappy O/D light flashing!!!Hesitation when acceleration!!!!
I have a mecury mystique 1999 V6 24V.....
My problem is that the O/D light is blinking now and when i pull off or atempt to accelerate it as a big hesitation....pls help this mecury is becoming a big problem....
Old 01-14-2009, 07:23 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: O/D light flashing!!!Hesitation when acceleration!!!!
What codes are you getting? That would help.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-06-2009, 04:53 PM
rhandwor rhandwor is offline
Some Ford's have a problem with a short in the shift control lever. Some take it apart and fix it some buy a new unit.
Old 05-13-2009, 07:37 PM
fatjoey666's Avatar
fatjoey666 fatjoey666 is offline
Bad news my friend. Mine was doing the same thing and 1 day later I lost all forward gears. Your check engine light will come on next and the code will read: Transmission slippage/ low fluid or bad transmission. Mine is the latter unfortunately. Hopefully yours is the other! Good luck!
